I have tried to convert an AVI file to MPEG using tmpgenc but every few frames or so the video is lost so while i still have audio i have no video
I have successfully converted many avi's to mpegs but i have gone thru the conversion guides and had a check in the forums
Any ideas would be greatly appreciated
Need more info!
What is your source material, what audio and video codecs does it use, what fps is it. Will it play ok in WMP. What is your destination format, (S)VCD or DVD, what settings or templates do you use in TmpGenc?
Give us some or all of this and maybe someone can help. -
Source is an xvid file.Destination is vcd.As regards codecs not to sure as i have sld codec pack installed.It plays in all media players i have including WMP, Power DVD ,Real PLayer,Winon VCD player etc..
Settings not to sure off because i just use the wizard to convert -
With Xvids, I would always recomend using virtualdub to frameserve them to TmpGenc, there is a guide on doing this in the CONVERT section, see if that helps.
Bugster did as u suggested and went to virtualdub frameserver but it wont work with tmpgenc
Any other ways round this problem at all
Thx 4 the help
What do you mean it won't work. What error message did you get (if any). If you get 'cannot open or unsupported' try raising the priority of the direct show filter. Also, don't foget to install the vdub avi client frame handler first.Originally Posted by Mark Warren
TMPGEnc Video Organizer
By TBoneit in forum EditingReplies: 8Last Post: 14th Dec 2012, 19:28 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc 4.0 XPress - audio only no video?
By Trang-Ly in forum Video ConversionReplies: 3Last Post: 2nd Jun 2008, 12:47 -
Converting Video for a Blackberry using TMPGEnc
By Vachoen in forum Video ConversionReplies: 3Last Post: 9th May 2008, 15:06 -
Tmpgenc producing Jerky video?
By love2learn in forum Video ConversionReplies: 7Last Post: 11th Nov 2007, 08:37
