Hi guys,
I just made a short avi-trailer using Premiere 5.1.
Everything works quite fine. I used the divX-Codec to compress the video - worked pretty good.
But everytime I use an audio-codec the audio is somehow shortened and doesn´t fit to the video anymore. It runs totally out of sync. The only chance I have is to use uncompressed audio, but that makes the files pretty big.
I also tryied to export the audio uncompressed an then try to convert it with virtualDub 1.4.7 using an audio-codec.
Same result!
Does anyone know where that comes from and what I have to do to solve that problem??
Thanx for your help
incident
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
M4V to AVI in VD, when compressed with Xvid, saves with audio out of sync
By kiki hayes in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2011, 09:45 -
Laptop runs REALLY SLOW!
By Squid_uk in forum ComputerReplies: 22Last Post: 6th Oct 2008, 22:34 -
video runs slow
By Madgelina in forum EditingReplies: 0Last Post: 8th Feb 2008, 17:45
