Anyone know of a way to put stuff recorded on a Philips DVDR 880 on to computer to ediit, like removing ads from a film eg?
One of the DVD ripper programs? Maybe? Check the tools section on the left for one of the rippers that will let you convert it to mpg or avi.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
I have made many films recorded in the format DVD+VR & AC3-audio with the following method:
1) Record film(s) to DVD+RW on Philips DVDR890. Edit with remote control on DVDR890 if necessary.
2) Rip the film from DVD+RW with DVDDecrytor 3.1.6.0 (don't use Smartripper at this step for recorded film if you edited it with remote control after recording)
3) Rename *.vob to *.mpg
4) Run Ulead DVD MovieFactory 2.0 (trial) -> add video files (*.mpg) -> edit/add chapters (in order to remove ads & unwanted portions) -> create DVD folder
5) Rip the dvd film created from step 4 with Smartripper 2.41 (split file by every chapter)
6) Rename again *.vob to *.mpg (of course without portions of ads)
7) restart Ulead DVD MF 2.0 -> add video files -> create DVD folder
(NeoDVD 4 has some limits and compatible problems with other standalone DVD players)
8) Burn DVD from the folder to DVD+R/-R with your favorite software.
Success!
bmt00 -
[quote="bmt00"]I have made many films recorded in the format DVD+VR & AC3-audio with the following method:
Thanks for tips.
I've tried as you say using above method, but the problem,
"VTS_01_1.mpg contains AC-3audio tracks, please convert...."etc
How did you manage to edit with AC-3 audio?
S -
Mr S,
Just click OK when you see those warnings. You cannot listen AC3-audio in DVD MF2 but it creates VOBs with AC3-audio if you check the option in the settings -> preferences -> "Do not convert compliant...".
Grtz,
Bmt
FireWire 800 unecessary for DV editing...BUT...
By Gromit137 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 09:05 -
FireWire 800 ... Worth It For Editing??
By Gromit137 in forum EditingReplies: 2Last Post: 19th Dec 2008, 18:08 -
Laser Etching DVDR That are NOT Light Scribe Discs.
By Scooter_NJ in forum Authoring (DVD)Replies: 4Last Post: 17th Nov 2008, 19:11 -
Will 720P and 1080P dvdr discs play on a Non Blu Ray DVD Player?
By donfm in forum Newbie / General discussionsReplies: 21Last Post: 31st Mar 2008, 15:45 -
Any recommendations for players that will play dvdr dual layer discs?
By vinland in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Oct 2007, 04:02
