I am using smart ripper and I am getting the following message. I have downloaded the latest ASPI driver and that didn't help. Here is the message:
FIND DVD E:\ something about mary
unlock drive
ASPI-Adapter Availabe
try to unlock drive...
Host Adapter Inquiry
swith to WIN10
test file access...
VIDEO_TS.BUP->WIN_1O readable
VIDEO_TS.IFO->WIN_1O readable
VIDEO_TS.VOP->WIN_1O readable
VTS_01_0.BUP->WIN_1O readable
VTS_01_0.IF0->WIN_1O readable
VTS_01_0.VOB->WIN_1O readable
VTS_01_1.VOB->WIN_1O readable
VTS_02_0.BUP->WIN_1O readable
VTS_02_0.IFO->WIN_1O readable
VTS_02_0.VOP->WIN_1O locked!
Done
Then another pops up box appears that says
SMARTRIPPER
Some files are still locked! Try to unlock with a player. Then your selection are ABORT, RETRY or IGNORE. If you ABORT, it simply ends, RETRY the same thing happens and IGNORE takes you to the next screen, but again, I don't know if we have all the key files.
Can anybody help and let me know what the heck the problem is?
Thanks Very much.
It means that you should play the dvd with a software dvd player(powerdvd,windvd...) first and then try rip it. You only need to play it a few seconds and then close the software dvd player and try rip. -
otherwise, just pause the player, rather than close it...that might help as well...
Hp ex495 media smart
By Marccc in forum Video Streaming DownloadingReplies: 3Last Post: 9th Aug 2010, 17:56 -
Get Smart backup
By Shermanbay in forum DVD RippingReplies: 26Last Post: 11th Nov 2008, 23:54 -
GET SMART no copy
By shoesss in forum DVD RippingReplies: 3Last Post: 7th Nov 2008, 09:48 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
