Hi,
I've been using DVDShrink since it came out and I'm very satisfied with the results. Recently however it started giving me this error message:
invalid nv_pck: nv_vobu_ea
I'm getting the message during the analyzing phase, sometimes during the encoding. Most of the time the program works fine I have this problem only with certain discs.
Any help would be greatly appreciated!
Cheers!
P.S. I'm getting this error with 1.03 and 2.2 versions.
Are you using it with disks or with files?
Many using DVDShrink first use DVDDecrypter to get the files on the hard drive -- not only does this remove RCE protection (which DVDShrink does not) but it also makes multiple recoding tries much faster. You might try this and see if that doesn't solve the problem with those disks."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Upgrade to Ver 2.3 of DVD Shrink,it's much more stable. I find it's direct from disk doesn't work well. As the other poster said rip with DVD Decrypter first.
Tried both ways. I get this problem only with certain discs /not dirty or scratched/. Most of the time the program works fine.
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17 -
DVDshrink error
By rubberman in forum ComputerReplies: 1Last Post: 3rd Sep 2008, 22:51 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
