Results 1 to 14 of 14
  1. Hi,
    Over the weekend i went out & bought myself Instant Copy from pc world.
    i Dont mind waiting longer for a Dvd if the quality is going to be better.
    Now the problem is everytime i try to do a film it scans the menu o.k & then when it moves on to scan the film 5 times, it gets so far then just stops
    I have not had any luck with this bit of software so far
    Not one film done with it....
    Can any one out there help me..
    I've read Mr Bass Guide on how to do it & its set up right and everything.
    IT JUST WONT WORK
    Can sumone please help me.......
  2. Hi i think that you should update the program. there are updates on the original page. But there are some dvds which cant not be copied with IC i had a problem with a movie stopping at 97 %
    But if the update doesnt work then you should use another program to make them to dvd-5.
  3. Thanks again Inja
    I thought that the update could be the answer to my problem but sadly it wasn't
    It still does not get past the part of scanning the movie 5 times....
    You got any ideas on what to use?
    i like Dvd shrink but with films That are to big i lose to much quality thats why i went out and bought instant copy....
    Thanks Inja for the advice Tho
  4. Banned
    May 2003
    Massachusetts
    I think the general consensus is that Instant Copy = Poo.
    I've never installed it, not even as a trial.
    - Gurm
  5. Try to disable the option where it say disable display. I had the same problem and after removing that oprion it works. In the mrbass guide there is a one tool for registry hack, use that and you will be change that option. Good Luck-B
  6. Disabling the Video preview should work btw make sure you have the latest Video Drivers for your PC.
  7. I Tried to Disable the video preview & it still just crashed but this time i had to wait over an hour for it to do it.....
    I got the latest Driver for my graphic card & it works perfect
    Cheers for the help
    Watty252
  8. it still just crashed but this time i had to wait over an hour for it to do it.....
    Can you explain what do you mean by this?
    And I am curious, how are you disabling the display option?-B
  9. Everything you need to know how to is here....
    http://www.mrbass.org/instantcopy/
  10. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Disabling Video Preview just like unchecking the box labeled preview in SHRINK is also possible in sub setting of instant copy
    but having bought, installed and updated it over here
    AND DONE OVER 20 BACK UPS WITH IT
    I will state that
    there , now I've sorta said it!
    BUT I STILL USE IT WHEN
    FAB Or SHRINK meet with problems
  11. Here are a couple of things you can try. Just a thought and don't flame me.
    First make sure you decrypted the DVD. I know it sounds silly but that sometimes would crash it. If you ripped the DVD with Decrypter, try to rip it again with DVD Decrypter. If you still fail, try using Smartripper.
    For DVD Decrypter, what I do, I usually just rip in file mode and I select all. I don't do the IMAGE ISO and DAEMON TOOLS or whatever that is. That's too much hassle for me.
    See if the above works. If not, then try the following to make sure your IFO files are not corrupt. Instead of using IC 7, run the movie through DVD Shrink and make it movie only and no compression.
    Then that will create a VIDEO folder with the new uncompressed movie only IFO, BUP and VOB files. From there, you can run IC 7 and use the newly created IFO files and see if that works for you.
    This will help you isolate the problems at least.
  12. Disabling Video Preview just like unchecking the box labeled preview in SHRINK is also possible in sub setting of instant copy
    My copy of IC -- with latest updates -- has no box for disabling video preview. Where is it located on your copy?
    LTA
  13. It's a reg setting...
    For more info go here:
    The Instanttool.zip 1.0.0.1 is what you want.
  14. I knew that. dcsos was a little vague.
    LTA
