I have many *.mpg's i would like to put on DVD-R's so i can watch them on my dvd Player (Eg. PS2 or Dvd-Player) . However im unable to find the right program to do so; so dvd's are playable. According to search in forum i here people recommending TMPGEnc. I have Used TMPGEnc & TMPGEnc Plus 2.5 With No Luck. I keep Getting Error Message Which i try to go back and fix but not an option. If anyone has the correct set of instructions or other software to use please let me know. Thank You!
what's the message?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
The Video Resolution 480*576 Cannot be used for a standard DVD but cannot find option to change it
at the bottom, click settings. there you should be able to change the size. 480x576 is not a valid dvd resolution.
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 18:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
k You!
