Hi,
I have Sony DRU 510A dvd burner. I made .ISO file of my own DVD successfully. When I burned the .ISO file on DVD -R nothing got burned. The whole DVD is empty. I followed the directions for copying DVD to DVD using the DVD decrypter. Can someone tell me what type of blank DVDs I need to use and which other software might be better for copying dvd to dvd.
newbie
Some people will say you must use high quality blank dvds. I have made numerous dvd using different type of blank media. I would practice on a dvd-rw first, you will be wasting big time money on blank dvd's. I assume
that you followed the dvd decrypter to the letter. You might have assume that the dvd was a single layer (dvd 5) and maybe the dvd was a dual-layer (dvd9). Maybe the disc is still blank, go to mode ISO click write and make sure you have your dvd in and see if it see empty or written. It should say that under status ( I am not for show if its called status, but you will see an area that say empty or written). I hope this helped you. -
I used Verbatim DVD -RW and everything went well. Now I need to try DVD -9. Thanks for your help.
newbie
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
