I've recently been trying to put some vcd clips on dvd, and I at first tried Ulead Movie Factory 2 for authoring then nero for burning. However, when I burn them the clips go out of sync eventually, more and more toward the end of the clip. I set it to NTSC (which is correct). When I use SVCD2DVDMPG the files come out in sync (if I do a separate vts for each clip, I haven't tried them all under one vts) but then I have no menu which is a little annoying. Is there anything I can try to fix this?
If you would like a simple menu you could use tmpgenc dvd author, to create a new "vts" for each clip add a new track for each clip.
But doesn't latest svcd2dvdmpg+ has a basic menu support?
DVD MovieFactory 6 Chapters
By BillyBollocks in forum Authoring (DVD)Replies: 0Last Post: 2nd Nov 2009, 13:26 -
dvd moviefactory 5
By bigz704 in forum Newbie / General discussionsReplies: 0Last Post: 24th Sep 2009, 14:54 -
DVD MovieFactory 6
By Mike99 in forum Authoring (DVD)Replies: 2Last Post: 24th Nov 2008, 05:14 -
Subs go out of sync in MovieFactory 6 when done in Media Subtitler
By rosbif08 in forum SubtitleReplies: 0Last Post: 14th Aug 2008, 13:04 -
DVD MovieFactory 6 Plus
By ozab in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2007, 16:48
