How would you convert ISO to MPEG2?
Many thanks.......
D
Never buy a dumb midget, its not big and its not cleaver...!!
ISO is an image of a CD, meaning all the folders... the whole works. Its not just a file to convert to MPEG2.
Eitherway, programs to open, names like Virtual DAEMON, ISOBust, or WinRar come to mind. A search on Google will likely yield websites with download links.
Also I think there are some guides on how to do this on this site. Check out the left hand column.
And if youre too lazy, just burn the thing onto a CD and open the CD.
Good luck. -
i may of phrased that question wrong..... i need to make a dvd out of an ISO image? TMPGEnc will not recognise it?
ahhh... in that case you do know what you're talking about.
I use Easy CD Creator, and in the File menu theres an option like Burn Disc From Image File. Im sure whatever you use has a similar feature, so just click it, select the ISO, and burn away. -
DVDDecrypter can also burn ISO to dvdr/ws.
www.dvddecrypter.com -
lovely! many thanks.......
D
Never buy a dumb midget, its not big and its not cleaver!
DVD to ISO or DVD to MPEG2?
By Yukiton in forum DVD RippingReplies: 5Last Post: 23rd Apr 2011, 12:48 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
ISO: frame accurate *multiple audio* mpeg2 editor
By febefe in forum EditingReplies: 1Last Post: 5th Sep 2009, 18:05 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 18:01
