Is there any good software for ripping the DVD9 to DVD5, I try InstantCopyftp://ftp.pinnaclesys.de/demo/InstantCopy7_trial/InstantCopy and DVD Shrink (I have 2 lower the video quality), is there any software that can allow me to remove only what I want to (Like Behind the scenes and extra audios, etc).
PLZ post reply![]()
well, DVDshrink allows you to just copy over the main movie files, w/o any menus or extras...you need to transcode in "reauthor mode"
in either case, if the main movie itself is over 4.38 gigs, you will have to compress it and lower it's quality to fit on DVD5...there's no way around it...
however, you can split the DVD9 to 2 DVD5 discs using DVDXCOPY or DVDFAB with no loss in quality whatsoever
Just wanted to say hello...
By Novice2010 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2010, 11:20 -
I just wanted to thank VIDEOHELP.COM :)
By MISS CHIEVOUS in forum FeedbackReplies: 3Last Post: 18th Sep 2009, 02:29 -
help wanted with h264
By raythebaker in forum Newbie / General discussionsReplies: 1Last Post: 27th Feb 2009, 15:06 -
Help wanted for DVDShrink 3.2
By _beavis_ in forum Newbie / General discussionsReplies: 13Last Post: 6th Feb 2009, 00:11 -
Just wanted to say thanks!
By freebird73717 in forum FeedbackReplies: 0Last Post: 30th May 2008, 16:10
