I want to backup a DVD to VCD.
I ripped it then created a project with DVD2AVI.
I have 2 files: project.d2v and audio MPA T01 DELAY -80ms.mpa
I start TMPGEnc -> project wizard -> choose files ....
It accepts both files, no problem.
My question: in the "Source range" window, should i put something in the audio gap correct box? Like 80ms or -80ms, cause the .mpa file has DELAY -80ms in its name?
Thank you in advance.
you need to put that number in somewhere or it will be out of sync and i dont see anywhere else it would go.put -80 in the box.
just load it into the audio section of TMPGenc, choose format(pal/ntsc)
hit start wait about 2-3 hrs. and you'll have your vcd -
Hmmm ... a little bit too concise, your answer .....
i would appreciate a little more elaborate reply. Any other opinions?
Cheers -
You only need to worry about the delay time when you are reencoding a movie and plan to use the original soundtrack. As far as creating a vcd or a dvd using mp2, there is no need to adjust the source range. If you are encoding both and audio and video file, the sound should sync just fine.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 08:34 -
MPA to AC3
By Benjy in forum AudioReplies: 6Last Post: 14th Jun 2011, 06:52 -
Merging MPA video and MP2 audio files
By makf in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2009, 19:13 -
Good free program to join .mpa audio and .mpg video ?
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2007, 09:34
