    Mar 2003
    SEVEN SEAS OF PIRACY
    Sometimes when I am converting a big file (over 6gig) with DVD2ONE I get the blue screen and a error message saying something like
    Beginning Dump of Physical Memory.
    I don't know if it is directly conected with the software but if anybody has had this problem or (even better) knows the solution because I am going out of my mind!
    Thanks Guys and Girls
    Pirate Prince
  2. Banned
    Dec 2002
    sounds like you need more memory
    physical dump BSOD sucks. I had it a few times on my old dinosaur of a computer, thank goodness for pricewatch and cheap upgrades
    Mar 2003
    Thanks mate, but I wouldn't have thought that to be the problem
    here is my system spec:
    AMD 2.gig processor
    512ddr ram
    60 gig 7200 h/d
    Nvidia g-force 2
    soundblaster live 5.1
    haupauge wintv pvr 250
    It also did it last night while I was using Instant copy??????
    I get a blue screen...........Beginning dump of physical memory......it counts upwards from 1 to 50 (somtimes higher) then re-boots.
    PLEASE GOD HELP ME!!!!!!
  4. Member wulf109's Avatar
    Jul 2002
    What OS are you using? Sounds like someone has been playing with the virtual memory settings and you don't have enough virtual memory. Try restoring your virtual memory to default settings.
    Mar 2003
    Yeah Thanks Wulf109 mate.
    I'm running Windows 2000!
    I have gathered now that it is nothing to do with the software because it has done it a number of times now. Usually when I'm converting something or rendering something. (editing using Media studio, Creating a video file with Cool 3d 3.5 e.t.c)
    Can you give me any tips as to what size my Virtual memory should be? (based on my spec above)
    I am a bit of a novice when it comes to P.c's. I can do what I wanna do but when the shit hits the fan I just kinda give up y'know?
    Cheers again mate.
    Pirate Prince
  6. I have similar problem like PP, I recently ripped a movie, not over 6gigs, then everytimes I keep getting the blue screen after I restarted my pc or the pc restarted itself, then I can't even get pass the logo after login again. My specs are:
    winxp + sp1
    amd 1.5mhz
    512kb ddr
    40 gigs
    geforce m400
    any1 has any suggestions to why I keep having this problem...even tho after i re-formatted everything clean, and the same problem happen all over again. Just a note: that I only used 10 gigs so far including the file I ripped...then the "death" blue screen came up 'n said: PFN_List_Corrupt, sometimes the messaged is PFN_IRQ_Less_then_Or Equal, other times it said Begin Physical Memory Dump.....
    I'm thinking the problem maybe w/ AMD processor...I'm thinking of switching to Intel processor from now on...anybody has any idea/suggestions?
    thnx...TB
