  1. DVD Decrypter keeps splitting .VOB files at 1GB each
    I went to tools - settings - file mode - under options it says file splitting i set it to none then hit ok and i still send up with 1GB VOB files.
  2. That`s what it`s supposed to do by default I guess.
    May I ask what you would do with a 5 GB file?
  3. The DVD standard calls for files that are no larger than 1GB, that is if you like at the original source DVD it's files are 1GB. I doubt that your ripper is actually spilting them.
    Againt thou the question becomes what are you trying/want to do?
