I have one big VOB file that i want to convert to MPEG without losing any quality how can i do it?
anytime you convert you will loose quality. what do you want to do with the vob? vcd, svcd, dvd?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
You don't have to convert it. A VOB is already an MPEG with audio muxed together. Use VOBedit or VOBrator and separate those suckers.
You'll end up with the MPEG video and the audio (AC3/MPA/PCM).I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
I want to burn it to a DVD i just want to edit some of the video and my fav editor wont take VOB files.
txpharoah.....Any guieds on how to do that without losing any video quality? -
Nothing to lose. You're just pulling the files apart.Originally Posted by David9799
Imagine this: a VOB is a peanutbutter-n-jelly sandwich. VOBedit pulls the bread back apart and separates the peanutbutter from the jelly. Re-encoding would have been eating the sandwich and then digesting it. We won't talk about the output.
Open VOBedit, demux the video, then the audio. I can't get it to demux both at the same time. Download it. It shouldn't be hard to figure out. I never had a guide. I just guessed at it, and took all of 5 minute to understand. https://www.videohelp.com/tools?tool=VobEdit#commentsI'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Thanks txpharoah.........That was easy now i have a m2v file and a ac3 file now what do i do?
ok i'm juts guesing what to do here so i ran TMPGEnc went to mpegs tools - simple multiplex - used the 2 files VOB edit made and hit run and i got a error saying packets cause buffer underflow?
Reduce MPEG-2 filesize without losing too much quality?
By yic17 in forum Video ConversionReplies: 10Last Post: 26th Oct 2012, 09:02 -
Covert .VOB to AVI with out losing quality. How ?!
By SB4 in forum Video ConversionReplies: 7Last Post: 29th Feb 2012, 19:46 -
VOB to something perceivable without losing quality and multichapters
By romashkin in forum Video ConversionReplies: 6Last Post: 14th Apr 2010, 15:33 -
Convert AVI to MPEG-1 without losing quality: What tool?
By GeekyChocolate in forum Video ConversionReplies: 8Last Post: 28th Mar 2009, 17:42 -
Want to convert from VOB to .mov without losing quality
By kleiber in forum MacReplies: 5Last Post: 14th Feb 2009, 08:00
