Hey I was going to buy a TV Tuner but i'd thought I would ask and see what everyone's opinions are, I'm looking for a Video card that can make the same quality video on computer as it is with the original. so if anyone has any suggestions to any of these TV Tuners please post. Also my friend has a Dazzle DVC-80 and at the bottom of the video there is a line that is distorted are there any ones that doesn't have this
ATI RADEON 7500 ALL IN WONDER DDR 64MB RETAIL
AOpen VA1000= Lite2 TV Tuner PCI With Wireless Remote Control
ATI TV WONDER VE C/W REMOTE
AVerTV Stereo TV/PVR Card
aslo if anyone can think of a better video card plz post
ATI ALL IN WONDER RADEON
Forget the TV Wonder. Forget the Aver.
Don't know much about the other one, but I'm willing to shoot it down blind.
I've got two Radeon cards, and they work great.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Like stated above, hauppauge wintv tuner card. Ati's drivers sometimes dont like Win xp. As well as if you do dual moitor support, ATI tv card software you cant drag picture from monitor to monitor.
I have a ATI AIW radeon the first AIW Radeon the tuner is not as good as the 8meg ATI AIW I had before some channel's do not come in that good. the old card's use a Philips TV tuner. If you want to record you might have that channel that does not come in good. i do not know about the new ATI AIW they might have better tuner's in them now. The ATI AIW is one of the best for backing up old VHS tape's to DVD or VCD but some old tape's I have tried to back up have some kind of NTSC problem that ATI AIW does not like to display right there is one fix use a world wide vcr and set it to pal and capture as pal. Also my Dazzle 2 has problem displaying this tape look's fine if I just watch it on TV. I saying this there are alot of problem with capture card not really that bad but you have to play a little with them. at www.pricewatch.com they have a ATI AIW for $50.00 dollars its also a capture card and you can also get a hauppauge later have the best of both world's. ATI AIW software also has filter's to remaster old VHS tape makes them look new. If you are going to capture VHS tape's get your self a Sima video copymaster for $50.00 dollars to remove copy protection from VHS tape's for backing up. Dazzle 2 is very good for captureing but does not have a tuner but great MPEG2 it has you can read more at www.dazzlegeek.com about the card its a fan site for the dazzle 2 to buy go to www.dazzle.com then go to http://www.shopharmony.com/ they have the best price on the DVC 2 also called the Dazzle 2. If you want a hauppauge get the PVR 250 or PVR 350. ATI , hauppauge, Dazzle make the best capture card's
I've only heard bad things about Hauppage cards personally but there is a new card out which is made by ASUS that uses a new chip the 10bit conextant cx2388x chip I've heard this makes better videos but is not supported by alot of software yet, any more ideas are greatly appreciated
My vote is for ATI AIW 7500(I have one and it works great)$130USD.If you already own a capturecard another option is to use a stereo VCR as your tuner and run it to composite/S-video in,VCR's usually provide a better picture than an onboard tuner and a VCR has a remote.You can get a new stereo VCR for $50.
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum Capturing and VCRReplies: 0Last Post: 24th Jan 2010, 22:39 -
tv tuner
By maryhigginsrice in forum Newbie / General discussionsReplies: 7Last Post: 17th Dec 2008, 18:07 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 01:42 -
TV Tuner Help!
By anony283 in forum Capturing and VCRReplies: 13Last Post: 30th Apr 2008, 09:30 -
High Definition TV? Tuner or no Tuner?
By aturjans in forum DVB / IPTVReplies: 6Last Post: 17th Mar 2008, 07:31
