Ok...Im trying to find out why my card wont capture so i uninstalled everything and swapped PCI slots... Didnt help, so swapped it back to its original slot. Tried to reinstall drivers but keep getting this error: (And yes i uninstalled all drivers, software, everything!)
Heres my specs:
Windows2000 SP3.
Pixel View (PV-BT878P+ (Rev.9F)
Conexant FUSION 878A
PlayTV Pro 5.23 software.
http://www.prolink.com.tw/2003/english/products/multimedia/playtv%20dvr%20tv.htm
Drivers at:
http://www.prolink.com.tw/2003/english/download/protv_multimedia.htm
One last thing...
Im always logged on as administrator..
just thought id mention that before someone asks.
I have the same problem in XP. Once you remove a driver, my XP does not allow installation of another driver for the same device.
Fortunately, I have dual boot. Absolutely no such problems with Win 98 SE.
I am also looking for a solution short of re-installation for XP -
Your kidding?
That would be just typical of a MS O/S..
Have u tried a registry tool like registry medic or something?
There must be a way round it...
This most usually occurs when there is a driver conflict of some kind.
Right click on My Computer, open up Properties, and go to the Hardware tab. Then go do Device Manager and check your Sound, video and game controllers. Make sure everything there has an active icon (the speaker icon) with no red or yellow in it. Also make sure there are no "unknown devices" listed. If either is true (red/yellow, or unknown devices) delete the offending device and reboot. XP should then correctly handle things."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Tried all that-does not help.
To check whether sound driver was problem deleted that- can't install that back-same screen. Checked all security settings though gpedit.msc-no luck.
Seems deleting driver is unacceptable to XP.
Big audio problem
By gynno in forum AudioReplies: 6Last Post: 18th Feb 2012, 22:39 -
Big problem with Russian Subtitles
By Earthling2000 in forum SubtitleReplies: 2Last Post: 21st Apr 2011, 21:05 -
Big Problem
By k_pratl54 in forum DVD RippingReplies: 7Last Post: 9th Mar 2010, 21:37 -
big problem with soundmax
By marlo in forum AudioReplies: 6Last Post: 23rd Jan 2010, 04:40 -
HandyCam > PC > VDM! Big problem!
By ChezDigital in forum Video ConversionReplies: 26Last Post: 23rd Jul 2008, 23:23
