Hi,
I need help here, please. Recently I downloaded a file fron the net with very unusual frame rate ( 20 fps and data rate 77 kbps ; audio in mp3 with 96 kbps and resolution 352 x 288 ).
The other parameters are ok but I'm trying to convert that frame rate of 20 fps to regular 25 fps for PAL - and you can guess === with no big success !!!
All the time I'm getting audio sync problems.
I've tried VirtualDub and I can not load the file into TMPEG Plus ??? ( I don't know why?).
Any help will be much appreciated.[/b]
"Life could be easier if we help each other"
Search the forum for 'Xesdeeni' and 'PAL' and 'Conversion'. There is a method Xesdeen created to convert from 25 to 30 fps directly using a telecine process. It should work for you as well. You will have to do a tiny bit of touchup at the end, to speed up your video by a fraction of a frame to get the full 25fps, but the jump is much less than trying to speed it up by 5 frames per second. The audio will only be affected by the final speedup to get it at exactly to 25fps, and it will only be a minimal change at that. The audio should be unaffected by the first step.
Impossible to see the future is. The Dark Side clouds everything...
How to change MKV from 50 fps to 25 fps skipping every second frame?
By andreyyshore in forum EditingReplies: 11Last Post: 5th Feb 2011, 14:09 -
Wrong frame rate (30 fps) for DvdMaestro. Any solutions?
By conax in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2009, 17:36 -
Variable frame rate (vfr) and 120 (119.88) fps video playback big problem
By lovyagin in forum Software PlayingReplies: 0Last Post: 22nd May 2009, 04:40 -
Frame Rate (fps)
By PaulBlok in forum Video Streaming DownloadingReplies: 10Last Post: 15th Mar 2009, 09:50 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
