  1. I recently purchased my girlfreind a Technika DVD 300 from Tesco's. Its very new there and a wicked little player. Plays VCD's and SVCD's off the shelf but it requires a multi region hack. After a week of hunting i found the only crack online i have seen. Gonna try it out at hers tonight. See if it works for you:
    To convert this player into a multiregion DVD player please follow these simple instructions (assume you are using the remote control unless otherwise stated):
    Open the DVD tray
    Press Setup
    Highlight the Custon Setup option using your remote, however do not hit Enter
    Press 3,3,3,3
    Now at a hidden menu, select 1 for region 1, 2 for region 2 or 0 for multi region
    Hit Enter to exit
    The guy who posted it assures us it has been tested and works. and it is the same hack as the Dansai DVD955 Hack!
    Hope thats been some help to you.
    Also i would like to point out that i have tried to add this player to the site but i cannot find anywhere online to link it to so it wont get approved. The Technika website has no reference to DVD players and Tescos dont show it online...its not on Amazon or Ebay....its like it doesnt exist.
  2. Tried it out tonight and it works fully. Have fun those who need it.
