I got nero 5.5. I read that all I have to do is click on VCD and drag the mpeg and burn. After that, I can just put it on the dvd and play it? Im wondering becuz, some of my movies are bin and cues, i usually just convert it to mpg and burn it as data cd. whats the difference between burning bin and cue with cdrwin and burning with nero? Does it still make a VCD?
Another thing, why are SVCD's all over 700mb's? I thought they were split into 3 files for 3 cd's?
Bin/cue are image files. Burn it straight instead of extracting the mpeg.
Use CDRWin/CDRdoa/Fireburner to burn a bin, because Nero does not burn images of multiple track VCDs properly.
If you like to use Nero, just chose "VCD" from the wizard, drag the mpeg and burn. If you burn the mpeg as data CD, you will end with a data CD, not a Video-CD. Only Video-CD is playable on DVD players.
(S/X)VCD are burnt in mode2, so you can fit up to 807/747MB on a 80/74min CD-R.
Continue reading the FAQ's.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to rip the video from (S)VCD CDs or BIN/CUE images
By Baldrick in forum User guidesReplies: 45Last Post: 4th Aug 2010, 05:56 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
