I recently needed to reformat my computer and when I had everything installed again, I went and installed my Adobe Premiere (I've tried both 6.0 and 6.5) but before it could fully load on it's startup, I kept getting a WMV9VCM.DLL error.
Frustrated, I installed my older Ulead Video Studio 5.0. On the startup, I got the same error. I went to the Microsoft site, and downloaded the setup for this WMV9VCM thing and it still won't work. I was hesitant to try and install it since I'm only running 98SE, and it's for XP. But I tried it for the hell of it.
Any idea what's wrong with it?
When you reformated it, did you completely erase the C: drive with your operating system and re-install winows?
That's a very odd error -- it appears that particular DLL is part of either a beta player or some sort of non-standard OS.
If I were you I'd reformat over again, put your OS on and start by installing Premiere -- don't install *anything* else first. Make sure you use your original disks. If the problem persists, contact Adobe support."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
I miraculously got the program to work. Don't ask how, cause I REALLY don't know. BUT, I can't render preview my work. I can export into mpeg, but I can't preview it all with my effects. It says the codec isn't found.
Either call Adobe support or post to the forums -- they are very helpful in both cases.
Sound problem with Ulead VideoStudio 11
By rogerhacker in forum Newbie / General discussionsReplies: 15Last Post: 16th Jul 2010, 19:41 -
Premiere CS 4 and keyboard problem?
By ermetekos in forum EditingReplies: 1Last Post: 7th Apr 2010, 04:15 -
Adobe Premiere problem ??
By 3thman in forum EditingReplies: 9Last Post: 1st Nov 2009, 17:23 -
Ulead VS10 sound problem
By theguy1991 in forum EditingReplies: 1Last Post: 3rd Dec 2007, 19:06 -
Can't get video to import into Ulead, premiere or vegas
By nagihcim1 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Aug 2007, 21:37
