What are your experiences with:
Dvd shrink
pinnacle instant copy
dvd2one
With making a dvd copy from a 2 layer dvd to one DVDR?
Which is the easiest to use?
Which makes the best quality?
Which one has the least problems?
Please share your opinion.
I know there are manuals one the left side of the screen but i want to know from as much people what the experiences are.
I began as a huge DVDXCOPY fan, then DVD2One then Instant Copy. Approximatly ~8 months of experience and the recent purchase of a Sony DVPCX875P changer has brought me to following strategy:
DVD5: DVDDecrptyper read/write
DVD9, movie is all I must have, movie only is < 5.5G: DVD2One
DVD9, movie only > 5.5G: DVDXCopy on 2 disc, keep entire DVD
Episodic: Instant Copy
I've backed up ~ 350 titles. I wish I had developed and stuck to this guideline for all of them, but I was learning as I went along so I have no regrets. Many of the newer programs, I have never even tried because I was always able to achieve my goals with the above. -
Which is the easiest to use? DVD2one
Which makes the best quality? Most likely Instant Copy.
Which one has the least problems? I have never had any problems with any of them.
I use DVD2one more than the others, but this is because I could care less about any DVD extras or menu on a backup DVDR (plus it is fast).
dvdshrink works quite well for DVD9->DVD5. i personally would like to keep everything intact in the DVD, while not having to spread the DVD9 discs to 2 DVD5....too expensive, longer time, and DVDXCOPY been giving errors.
however, for those huge DVDs, DVDshrink would require compression of 50%. the main movie still looks great at that compression ratio on my 32" TV. however, the extras become noticeably worse....however, i suspect that the extras weren't encoded with a high bitrate to begin with, so compressing those by 50% would produce noticeable artifacts...but overall, i'm pretty happy with it.
pros:
1) it's free
2) it's one of the fastest, if not THE fastest
3) constantly being updated, so bugs get fixed pretty quickly
cons (at least for me):
1) filesize prediction isn't very good.... (i.e. if dvdshrink predicts the output filesize is going to be XXX MB, it may end up being XXX + 30 MB) so, if you're trying to fit as much as possible on a DVD-R, you might sometimes go over the limit
2) the compression ratios are given in 5% increments (i.e. 5, 10, 15,...., 50% compression) there is NO slider bar where you can adjust the compression by increments of 1%. this can be a problem if 15% compression of the main movie would be 1 MB over the limit. however, the next compression level of 20% might leave like 100 MB of extra space on the DVD-R.
update: just to clarify, the 5% increments hasn't really bothered me very much though because if there's any extra space, i can decrease the compression level for the menus, main movie, and extras separately, rather than as a whole. so, usually extra space on the DVD-R isn't a problem.... -
So far, for my needs, DVDShrink does everything that I need. 've just begun to touch the surface on what I want to do with this whole DVD burning stuff, so my "needs" may chnage in the future. But for now DVDShrink is easy, quick, and has worked every time.
vhs to dvd experience
By victoriabears in forum Capturing and VCRReplies: 0Last Post: 20th Sep 2010, 19:10 -
Why don't you need special "accurate" ripping programs to copy DVDs?
By sldvd in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2010, 05:30 -
DiscPainter CD/ DVD painter by DYMO - Anyone with experience?
By arcorob in forum MediaReplies: 4Last Post: 31st Mar 2010, 22:32 -
My VHS to DVD experience
By Oob in forum Capturing and VCRReplies: 17Last Post: 26th Oct 2009, 21:10 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51
