  1. I finally captured 2hr home movie VHS to 5.6G MPEG2.
    It plays fine in WMP but can't encode it with TMPGEnc...computer freezes!
    I did successfully encode smaller 10 min. test movies but my computer
    couldn't handle the 5.6G file encode.
    If it plays fine now...Why encode?
    Is it required for DVD burning/playback?
    If I need to encode then how to keep computer from freezing?
    I captured IAW Lord Smurf's fantastic VHS to DVD guide with
    zero dropped frames...What is it that TMPGEnc requires that
    freezes my computer?
    Mar 2003
    Uranus
    One minor problem is that your 5.6G file
    will not fit on a DVD R and the only way
    to fix it is to re-encode (or trim some off)
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    your file is an mpeg-2, so it's already dvd compliant.
    what are you trying to accomplish by running it through TMPGenc?
    if you are looking for a smaller file size, you should recapture your original at a lower bitrate rather than reencoding, as the quality will be better.
    or you can author your disc at 5.6Gb and use DVD Shrink or DVD2One to drop the size.
    check your audio as well - make sure it's AC3 or MP2, and not PCM wav format, as PCM is exponentially larger and wastes space.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
