Without a dvd burner I mean? Im so sick of converting m2v files.
why are you converting them?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
because in order to have the files on a regular vcd i have to convert them to mpg
where are you getting the files?
m2v files are usually svcd mpeg 2 files...so as long as you have the mpeg2 codec installed (easiest way would be to install powerDVD/winDVD), then you can just change the file extension from .m2v to .mpg and it should play normally...even on win media player.
you can use nero to directly burn these .m2v files onto a SVCD.
if you want to burn the file as mpeg 1 VCD, then yes..you do have to re-encode them.... however, if you can burn the file as higher quality SVCD, then try that first, unless your dvd player doesn't support SVCDs
Cannot burn an mpg on a DVD
By costaseco in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2009, 04:15 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
Burn MPG file onto DVD
By geek2330 in forum Newbie / General discussionsReplies: 15Last Post: 2nd Oct 2007, 09:51 -
Burn mpg on DVD
By knowmyname_20 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2007, 20:31 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
