Helo all!
I've been using TMPGEnc but found out it's not perfect as it comes to
good compression for DVD-R. Comparing other mpegs that are VBR
quality is much better. I can see that bitrate is almost constant around
4.1Mbit/s. I set max bitrate 9500 min 0 avg 4100. What do I do wrong?
All Mpg2 files are crap comparing to those done with f.ex. dvd2one.
Image crispier smoother and no motion pixelation.
Could that mean TMPGEnc sux?
I heard adobe plugin is quite good.
I need some professional soft recommendations. Please help guys.
Well if ya have plenty of money to spare, CCE or CinemaCraft Encoder is one of the best solutions out there. I would suggest you try out the trial lite version, and if you like it, you can either get the basic package for $58 I think, or the professional for >$1000. Either way, its something else to try and works out very well.
MPEG2 transport stream software
By PCNG in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2009, 15:10 -
DVD authoring programs and their MPEG2 encoders?
By Valnar in forum Authoring (DVD)Replies: 7Last Post: 27th Dec 2008, 10:26 -
What FREE software for .avi DivX Xvid etc to DVD do you use? and encoders?
By mcv2008 in forum Newbie / General discussionsReplies: 10Last Post: 28th Jun 2008, 11:08 -
Free software Mpeg2 -> DVD
By mpeg22dvd in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2008, 16:56 -
Software Recommendations for Capturing MPEG2
By scienceguy_4 in forum Capturing and VCRReplies: 7Last Post: 4th Oct 2007, 20:59
