some will know this, some won't,
1)defrag your hard drive
2) stop all uneccesary backgroud programs
3) set tasking priority to high
4) disable preview (enable it every now and then when you want to check progress)
5) use multithreading if you have more than 1 processor
6) frameserve video from avisynth
7) if not use vdub
8) instead of noise reduction filter use dynamic field order correctiion filter for vcd/svcd
9)set motion search for high instead of highest
all comment and suggestions good or bad are welcomed
Hi Secretagent,
As everyone knows, using TMPGenc's Noise reduction really increases the encode time by 2x or more, and obviously you knew it and suggested to use Dynamic Field order filter.
My question is, is this the equivalent of TMPGenc's Noise reduction? Where can I get this filter, I tried searching on AVISynth web site and found nothing...can you possible let me know where can I download it?
Thanks.
Seanandredj -
Originally Posted by secretagent
so far, frameserving through dvd2avi is the fastest for me when compared with vdub and flask.
also, filters in general slow down the encode time. however, i've personally had to resort to some of them. i.e. the deinterlace filter has come in handy when those interlaced lines appear (yes..even when forced film in dvd2avi on 95+% FILM source). deinterlace filter per se doesn't increase encode time very much because it applies the filter throughout the movie...however, i chose to sacrifice encode time by using the adaptive de-interlace filter, which takes considerably more encode time because the CPU is determining whether a video frame needs to be de-interlaced or not...so that the filter is not applied uniformily throughout the movie. hence, for certain filters...it may be a tradeoff b/w encode time and a slight improvement in quality.
Ideas or tips for building computer (mostly for video editing/encoding)
By robjv1 in forum ComputerReplies: 13Last Post: 14th Jun 2011, 14:21 -
need encoding tips for better quality PS3-friendly MP4
By spicediver10191 in forum Video ConversionReplies: 6Last Post: 13th Mar 2011, 05:48 -
how to speed up rendering time with HD video
By The Linguist in forum Newbie / General discussionsReplies: 1Last Post: 17th Dec 2009, 05:31 -
Seeking audio encoding upgrade tips
By vhelp in forum AudioReplies: 2Last Post: 25th Jan 2009, 19:33 -
Lower video encoding tips for small 7 inch screen
By hauns in forum EditingReplies: 5Last Post: 9th May 2007, 13:54
