Hi,
I have been doing some research on video card and capture card. What I want to achieve is capture TV programs / VHS and burn them on DVD.
I am new to this and have a few questions:-
- Do these two cards (ATI All-in-wonder 9000 / 9700 Pro) allow capturing to MPEG2 format? Can they do a good job?
- What sound card would be good to go with these two cards?
- Is a high end video card needed for capturing to MPEG2 format? Or is it really a high end capture card more crucial?
- I used to have ATI All-in-wonder 7500 and had so much noise in the captured audio tracks. Could an on-board sound card be the problem?
- If I am getting a new Intel Pentium 4 machine (2.4-2.6 GHz) , what hardware configurations would you suggest (motherboard, type and size of RAM, etc )?
Any suggestions would be greatly appreciated.
Thanks,
Stupidmice
Yes they both capture capture in MPEG-2 as well MPEG-1, AVI, Trigger Motion, Windows Media and of course ATI's VCR mode. I have a 9700 AIW pro setup with an additional ATI TV Wonder VE for two tuner capability, called multi-view or Picture in Picture. I use mine all the time to schedule, record and author DVD's which look like the original source. It up to you wether or not you need a high end card. Alot of people swear by the Canopus Capture Card (Model?). The ATI cards do alot more than just capture with their Multi Media Center Software. I have run nothing but Sound Blaster Audigy and Audigy 2 sound cards. Have never experiencing any sound issues with any program. I never subsribe to on board sound as a permenant solution. As far as configuration I will only say this, buy the best your money will allow. There are alot of good motherboards out there with alot of features. Determine your requirements and go from there. I run a P-4 2.4, 2.5. 2.8 and 3.03 as well as a few AMDs. Buy at least 512 of RAM but 1gig is what I run, plenty of head room. I like Corsiar Ultra Ram. Hope my 2 cents helps.
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 13:41 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
ati tv wonder pro
By rcomp in forum Capturing and VCRReplies: 0Last Post: 26th Mar 2009, 23:14 -
Logitech Quickcam 9000 Pro
By Tyler2000 in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2008, 16:22 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27
