I've been capturing off of 8mm tapes to an avi file and encoding with TMPGenc plus (using default settings) followed by TMPGenc dvd author.
the first 5 dvds came out great. All files were convereted using Tmpgenc "defaults" (whatever the wizard came up with):
most files were converted at 720X480, one at 352X480, all at 29.97 fps. And the maximum bitrates varied for every file from the 3000s range to 8000! All looked great once put on dvd.
The last 5 hours of video I captured have poor quality with a lot of pixlation especially where there is a lot of movement. Here's what I did differently:
1 I overrode the resolution from 352X 480 to 720X480, thinking this would give me better clarity. (Would changing this resolution setting not help the quality?)
2 I performed a batch encoding of two avi's.
Could the batch encoding have caused a problem, or should I not fool around with the resolution setting the "wizard" comes up with?
The avis for these files have since been deleted. Do I need to recapture the 5 hours of vieoor can I do something with the m2v files I've still kept to improve the final DVD output?
Thanks for your comments.
Since we do not know what TMPGEnc is using for settings now, you may want to try to set your own settings with a DVD-RW. Anyway, when you open the wizard, select the appropiate DVD template (NTSC/PAL), the continue with the way you ran your wizard normally. You do not have to encode the entire video again, just a sample, about one minute or so, and about the encoding. The sample will be in the file you named. Burn this file to a DVD and see what happens.
Hello. -
Originally Posted by unstuck2
when you increase the resolution, technically...you're video will look sharper...BUT that is if you increase the bitrate.....otherwise, if you use the same amount of bitrate for both 352x480 and 720x480, each pixel in the latter will have less bitrate allocated to it, despite having more pixels overall.
so...if you don't change the bitrate, but do change the resolution..here's what's gonna happen...
higher resolution->sharper, but more macroblocks (just plain blockiness)
lower resolution->less sharp, but also less blockiness
it's a tradeoff
2) batch encoding shouldn't affect the quality... -
Originally Posted by poopyhead
Example:
720x480 at 3.0 MB/s will be crap quality (takes 8.0 to be perfect).
352x480 at 3.0 MB/s will be pretty decent quality (take 4.0 to be perfect).
Upping the res won't accomplish anything if the source if not 720x480. Your 8mm tapes are about 325x220 (digital approximate of your analog source). The 352x480 is already better than your source (keep it here).I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Originally Posted by txpharoah
however, macroblocks is not completely dependent on bitrate...it's a combination of bitrate and resolution..for the purpose of clarity in my example, i kept the bitrate constant to illustrate the effect of different resolutions on macroblocks.
it could also be seen by keeping the resolution constant, but changing the bitrate...with more bitrate resulting in less macroblocks
A 720x480 8.0 MB/s will be sharpest.
A 352x480 8.0 MB/s will be sharp, though less than 720.
However, those are not typical uses of bitrate/res. But fine for an example to illustrate your point.
Maybe you meant DV? In that case, go for 720x480 at 4.9+ MB/s. Stick to 8.0 to avoid any possibility of macroblocks.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
thanks guys for all the replies. This is very helpful.
Unfortunately last night before bed, I started another encoding project that is burning right now. I made some guesses as to the settings: 720X480 @ 3.638MB/sec. I also changed the motion search to Normal from the default estimate search. This made for a 4 hour encoding of a 2 hour video! After reading your responses, I am not too hopeful about the quality I am going to get. (BTW I do the full video instead of a snipette because to see it on my DVD player I have to burn a DVDR anyway)
For 8mm tape projects from now on I'll stick to 352X480 and keep the bitrate as high as possible. do you use "constant quality" in the TMPGenc settings and punch in the bitrate setting you want? There has to be a guide on this here somewhere (I'll look).
I think the confusion with the resolution came from the first project I did which was off of a DV, and TMPGenc DVD author does not let you mix two different resolution videos on the same track, so I decided to do everything in 720X480.
Thanks again. I'll let you know how the one I'm burning now comes out. Good to figure it out though, I have ~15 more hours of 8mm tape to go through!
After a certain software (may not even exist but thought id ask!)
By SE14man in forum ComputerReplies: 16Last Post: 18th Oct 2011, 18:36 -
Need your thought's on these new SHM-CD Format Disc's?
By VEBouto in forum AudioReplies: 3Last Post: 16th Aug 2010, 05:19 -
Making Movies is More difficult than I thought
By Alextaylor in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2008, 01:16 -
Movies Everyone Liked, But You Thought were Crap
By Ironballs in forum Off topicReplies: 62Last Post: 4th Dec 2007, 10:07 -
Thought for the Day
By ahhaa in forum ComputerReplies: 2Last Post: 26th Jul 2007, 11:56
