Results 1 to 13 of 13
    Mar 2003
    Laredo,Tx
    i have been ripping Television shows of a dvd into XVCD. well they are mpeg 1, and i use CQ i wanna know if this is compatible on a dvd-r or +r whatever. please i need to know so i can either keep going on doing my shows this way or stop and settle for less quality.
    An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php
    Mar 2003
    Laredo,Tx
    come on ive had 21 views and no replys. come on i need to know. everytime some one has a question that i know i can answer i do it so why cant i ever get my shit answered.
    Mar 2003
    Laredo,Tx
    is it because the question is stupid or is it because the people who have viewed my forum dont know what im talking about. i think i heard its not compatible, but will it still work on sevral dvd players and by several i mean quite a few.
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    could be that.
    could also be that you're pretty impatient, bumping this thread three times in one hour.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    Mar 2003
    Laredo,Tx
    could be that.
    well yea but its cause i see all those views and yet no replys.
    Mar 2003
    Laredo,Tx
    oh and how about you housepig would you know how to answer my question?
  7. That answer is quite simple, depending on certain
    things of course, you should begin capturing way
    higher, BTW what is cq? what capturing mode are
    you using? which format? hop many episodes
    and how long are they, you wanna fit to a dvd?
    Some authoring programs will convert mpg to
    dvd for you, depending on source... but then
    you may run into audio problems cause source
    is incorrect, it needs 48khz not 44.1...
    Mar 2003
    Laredo,Tx
    no i am not capturing for i do not have a capture card although i wish, but right now i got other things in mine. what i am doing is i own a dvd of Sex and The City. and im ripping all of them and encoding to XVCD. and CQ is Constant Quality. its like VBR, but only 1 pass and you get great results. probably better than VBR. ill tell you you get better results than CBR. and yes i know about the whole audio needed to be 48 khz i know all that just wanna know if XVCD with CQ is compatible on most dvd players like a DVD-VCD would be?
    May 2003
    Phoenix, AZ
    I don't know anything about XVCD but I read that you can use a program like DVD-Lab to put SVCD (480x480) onto a DVD.
    According to the author, he has had pretty good luck getting them to play back on his DVD players. I think SVCD is MPG2 and you have to of course change the audio to 48 kHZ. I'm not sure what XVCD is or what it uses.
    Look here and see if that tells you anything.
    http://www.mediachance.com/dvdlab/tutorial/svcd.html
    Howard
    EDIT: BTW, I really like CQ (Constant Quality) encoding too.
    Mar 2003
    Laredo,Tx
    Howard
    no no no this has nothing to do with SVCD i know its mpeg 2 i konw its 480*480 i know it has 44.1 khz audio and i know thats not standard audio. i know it has to be 48 khz and all of that. XVCD is MPEG 1 and XSVCD is MPEG 2
  11. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    nope... I don't do XVCD.
    that's why I'm one of the "multiple views with no response" posse.
    - housepig
    Housepig Records
    out now:
    Mar 2003
    Laredo,Tx
    well then ok
    Mar 2003
    Laredo,Tx
    come on anyone. the question is not hard at all. the only reason i dont know is because i dont have a dvd-burner to test alot of things out. and being that alot of people in this forum have dvd burners well someone has to know what and how to make xvcds. and those that do proabably have tried to transfer them to dvd-r. i never XVCD neither, but these episodes are about 25 or 27 minutes average, and on the dvd each show is approximatly 1 GB in size and well i tried CVD with a bitrate of 2000 and the size was 400 MB per show and well i didnt like the resutls they were pretty crappy compared to the XVCDS i had made. yes im a big fan of CVD right now because i dont have a dvd burner, but when i do everything will be in dvd reseltuion, unless i already made them to cvds and they look good enogh to put on dvd which all of my cvds look good enogh to be on DVDS.
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Baldrick
    PLEASE wait at least a few days before you bump your topic. / Baldrick
