Hello
I recently bought a dvd burner and am currently trying to put my home videos onto dvd-r. I captured using a Radeon TV Wonder and the resulting mpeg-2 file looks great. I thought I could just burn this straight onto a dvd-r but I used NeroVision Express to author and burn it and when I play it back on my set top it looks like crap! Complete compression artifacts! My question is can I just take the uncompressed video of the mpeg-2 and burn it straight to dvd-r and what program if any will allow me to do that. Any help is very appreciated!!! Thank you!
Scott![]()
DVDLab lets you import mpeg2 files and author them... it is a robust authoring solution and lets you get very creative with what you can do...
Just make sure you mpeg2 files are dvd compliant... ie 720x480, bitrate from 2000-9000 mbps, 48khz audio,etc.... -
The problem is probably that NeroVision is reencoding your file. I would agree with Don2050, DVD Lab is a great program, it packs a lot of bang for the buck, and it won't reencode your files. (If they aren't truly dvd compliant, they will fail when you author, though).
even if you don't go DVD Lab, you should find another authoring application that won't reencode your files, or see if there's a way to turn off the encoding in NeroVision.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Youtube newb help
By Shizam in forum Video Streaming DownloadingReplies: 8Last Post: 17th Aug 2010, 15:04 -
New newb with old question
By Madzir55 in forum RestorationReplies: 4Last Post: 17th Jan 2010, 12:05 -
Newb FCE Question
By Jralph in forum MacReplies: 3Last Post: 17th Apr 2009, 10:56 -
Newb- capture help
By davidc2478 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Jun 2008, 18:58 -
Hi NewB here with some serious problems..
By *Equilibrium* in forum Software PlayingReplies: 3Last Post: 30th May 2007, 09:22
