Hello
I am a newbie.
I have a Matrox RT2500 card for NLE editing.
I want to enquire that for good quality is it necessary to purchase expensive hardware MPEG1 Encoding cards. I dont have a hurry to Real Time Encode my edited movies, i,e time is not the issue so the real issue is quality.
My questions are
1- If time is not the issue, using same bitrate will the Software encoders like TMPGenc will give greater quality than a hardware encoding card?
2- Someone told me that there are frame dropping and jerking issues with software encoders which is not the issue with Hardware encoders. Is it correct?
Thanks and bye
hardware encorder use to be better 6 months ago. now that not necessary the case
i sold my quartet mpeg2 encorder card when instantcopy 7 came out
i have a aver dvd capture card
and i only use that for old vhs tapes -
Remember that there is no such thing as a "hardware encoder": it is merely a software encoder running on a DSP, and usually not the best encoder.
The only advantage of a hardware encoder is relialability (no other tasks running on the DSP chip), and offloading the work from the main CPU.
If you want the absolute best quality, it requires capturing uncompressed, applying filters, editing, then only do the encoding at the final stage, possibly using a 2-pass encoder.
The best MPEG 2 encoding software?
By whatever911 in forum Video ConversionReplies: 20Last Post: 8th Oct 2012, 08:54 -
Hardware vs Software Encoding
By gabs247 in forum Capturing and VCRReplies: 49Last Post: 28th Mar 2010, 19:31 -
Hardware Encoding
By jeby1980 in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2010, 23:03 -
Software or hardware encoding for project?
By stantheman1976 in forum Video ConversionReplies: 2Last Post: 11th Jun 2008, 15:53 -
TV tuner with hardware MPEG encoding
By mb508 in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2007, 07:52
