All,
I'm trying to figure out if there's a simple program to add chapter points to my mpg file before dropping it into my DVD program. My dvd program (MyDVD) that I use does not allow the creation of chapter points after the fact, so I have to do it in an "outside" program.
Any suggestions?
Thanks,
Anthony
Chapter points are a function of the authoring process, so your authoring program will need to be able to make them.
My major problem is that I'm using a bunch of freeware, can't afford "good" programs, and I'm basically doing the AVI->MPG conversion thing. But, I can't insert chapter points while encoding to mpg.
Is there no possible way to do this after the mpg has been created?
Thanks again,
Anthony -
No I don't know of a seperated CHAPTER maker
BUT Three DVD authoring programs that support what you want to do
1. TMPGENC Author..$60
2. DVD Lab $100
3. DVD ARChitect $350 -
IFOEdit does have a DVD authoring mode where you can add chapters. It wouldn't be useful for anything else really, except this.
It is freeware - you may wish to try this.
PAL to NTSC Chapter Points
By sambat in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2009, 08:52 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 18:38 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
