Geez, i lost it all. I can't even remember how to put chapters on a SVCD. I know i did it a few times already but whatever i try, it won't work. VcdEasy doesn't open the mpeg file and Ulead moviefactory trial took like 3 hours converting streams (while it shouldn't be doing that) and the it says the file is too big. Can anyone tell me a simple way to put chapters on a Svcd (i copied the mpeg file to the HD), without menu's or thing like that.
Thnx,
Phoenix4
VCDEasy is the easiest way.
Mind you, a SVCD has to have the MPEG-2 files at particular specs: https://www.videohelp.com/svcd
If VCDEasy doesn't even open your MPEG-2 file, there may be something wrong with it. I would suggest that you at least try to remux it with TMPGEnc (Files --> MPEG Tools --> Simple Multiplex) or bbMPEG and try again.
Then, you make the chapters with VCDEasy like you would for any other VCD. There are guides on this site that explain it in detail.
If VCDEasy continues to refuse to accept your MPEG-2 file, there is undoubtedly something wrong with it and you are unlikely to get anywhere very far with an other proggy.
Regards.Michael Tam
w: Morsels of Evidence
Want simple tool for chapter links within single mpg file
By salring in forum Authoring (DVD)Replies: 2Last Post: 7th Jan 2011, 22:21 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
DVD Chapter Question.
By firewaterjoyride in forum DVD RippingReplies: 2Last Post: 18th Aug 2007, 23:05 -
Chapter question
By BCbear in forum Authoring (DVD)Replies: 15Last Post: 30th Jun 2007, 08:52
