When capturing video, we have the option to encode it to NTSC which is 352x240 @29.9fps or PAL which is 352x288 @25fps. Which format will provide a clearer picture?
Another question, using the TMPG to convert MPG file from one format to another, will it lost certain clarity of the video?
It isn't a clarity issue. It's an issue of where you live. NTSC is for North America, and PAL is for most of the rest of the world.
If you don't capture using the correct setting for your area, when you play the video back on a television, it's going to be all dicked up.
Yes, if you convert between the formats, you are going to lose quality. Not in the frames themselves, but in the frame rates. -
I agree with Beretta of course, but PAL has a slight advantage over NTSC. This would be the extra 48 vertical pixels, which might seem negligible but it's actually 20% of the NTSC vertical resolution. So by simple mathematics NTSC resolution is 83,3% of PAL resolution and this can make a difference.
Since most modern DVDs and TVs are able to display both formats maybe it's worth using PAL even in NTSC countries.
______________________________
VCD Intros and more...
http://welldone.freehosting.net
<font size=-1>[ This Message was edited by: SupaCoopa on 2001-09-28 05:21:09 ]</font> -
What about the frame number? NTSC 29 frame persecond, PAL 25 frame persecond, does it mean that NTSC should have smoother picture than PAL ??
karhooi: a dvd is actually in film format (23.976FPS) do you see a less smooth picture compared to say, an ntsc vcd?
yoshi1668: inherently, pal is a better format. if you're viewing on your computer, then pal (for ntsc regions) is just fine, but if you plan to have it ntsc compatible, then obviously, you would want it in ntsc format! the reasons that pal is a better format include what SupaCoopa wrote (higher resolution) but also, better colour reproduction. (NTSC has been coined by some as "Never Twice Same Colour"
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL aspect ratio 2.35 format to 16:9 NTSC
By chowa in forum Video ConversionReplies: 7Last Post: 2nd Feb 2008, 18:16 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2007, 00:26 -
using pal material to work in an ntsc format
By rapidondamove in forum MacReplies: 2Last Post: 7th Jun 2007, 17:22
