I just started using my Adver TV tuner card. I hooked it up to my cable tv line and was able to watch tv. I tried to capture using Power VCR 2. I was able to preview everything wit sound etc. Every time I capture and try to see test the file or burn the file I get video without sound. Am i missing something. Appreciate any help. Also is the Power VCR program good for captures or is the Snapstream product better? So far the video I captured looks less than VCR quality even though I set to the highest quality MPEG 2.
Rob
Have you checked your recording volume to see if it is selected?
Hello. -
Define fine? Is it selected? Did you plug your audio into line in or mic in? Can you record sound with 'sound recorder?' Did you select audio source from linein in your capture software?
Sorry I am wrong. I have no audio cable hooked up in the back of the computer. The tv card has what appears to be two audio sockets and I have some audio cables that came witht he tv card. I connected the soundcard recorder into the tv card via one of the audio sockets. I still cant get any sound. How is this supposed to be setup. I have a cble into the tv card.
rob
NO sound when capturing with Ulead SE 11
By TheKillerQueen in forum Capturing and VCRReplies: 41Last Post: 13th Mar 2012, 03:55 -
sound interposition when capturing from tv
By eliqush in forum Capturing and VCRReplies: 0Last Post: 7th Oct 2009, 17:35 -
No sound when capturing video ???
By j4mes_bond25 in forum Capturing and VCRReplies: 6Last Post: 10th Aug 2009, 12:03 -
Capturing Audio in Sound Recorder
By ViRaL1 in forum Off topicReplies: 3Last Post: 2nd Dec 2008, 03:26 -
No sound while capturing from Sony Handycam to PC
By Tony11 in forum Capturing and VCRReplies: 1Last Post: 24th Jan 2008, 23:51
