I was converting divx->mpeg1 for OCEAN'S ELEVEN using tmpgenc 2.513. In the 21st miute of the movie I get "Stream Write Error" and the encoding is terminated. DO u know what it means and what is the solution?
It is a NTFS and I have a WinXP Pro.
File (divx) size is 700MB
I have used the same procedure before to convert other divx files. But this error never came up. If I try another divx file, it converts fine as well. -
Maybe the file is damaged. There is a DivX fixer in the tools section that you can run to see if there are any errors. I've had DivX files that seemed to play fine on my PC but had issues when encoding to mpg2.
Howard
Error: "There is no subpic stream for the menu......." What does
By tplowe56 in forum DVD RippingReplies: 4Last Post: 23rd Apr 2010, 11:06 -
corrupted m2ts file - "cannot detect stream type"
By ac1j2 in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2010, 07:51 -
Camtasia Error : "Unable to write AVI file frame"
By ShinuMirai in forum Newbie / General discussionsReplies: 8Last Post: 11th Oct 2009, 15:19 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 17:20 -
Clonedvd error"Media Write Error"
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 02:49
