I am using VCDeasy 1.16 and come up with the same error when attempting to copy an mpeg file. My burner is LG 8083B and my aspi driver is 4.60 and that is fine. I am using generic MMC for a driver for the burner. I was using VCD 1.15 and have had previous success with this program. It stopped working when I downloaded windows media 7.1. I have since uninstalled windows media but still cannot get this program to work. Any suggestions anyone. Thanks
[Internal Xml Generation]
Internally computed XML generated successfully: "D:\VCD\videocd.xml"
[00s 110ms (Internal Xml Generation)]
[VCDxBuild.exe]
GNU VCDImager 0.7.12
initializing libvcd 0.7.12 [cygwin/i686]
changed volume number to 1
changed volume count to 1
changed restriction number to 0
changing 'next volume use sequence 2' to 0
changing 'next volume use lid 2' to 0
changed volume label to `FUSION_X_14'
changed publisher id to `VCDEASY_V116'
changed application id to `CDI/CDI_VCD.APP;1'
changing 'relaxed aps' to 0
sequence count 1
adding sequence #0, D:\Enterprise\Star Trek Enterprise - 1x17 - Fusion.mpg
strange (possibly non-compliant) user_data seen... (not a problem, usually a sign of TMPGEnc)
APS' pts seems out of order (actual pts 72.979300, last seen pts 73.012667) -- ignoring this aps
APS' pts seems out of order (actual pts 1690.161533, last seen pts 1690.194900) -- ignoring this aps
pts start offset 0.340078 (max pts = 2661.331744)
playing time 2660.991667
scanning mpeg sequence item #0 for scanpoints...
already scanned... not rescanning
pbc: psd size 0 (extended psd 0)
iso9660: highest alloced sector is 224 (using 300 as isosize)
writing track 1 (ISO9660)...
writing track 2, MPEG1, NTSC SIF (352x240/30fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
MPEG packet statistics: 166605 video, 32695 audio, 0 zero, 0 ogt, 293 unknown
writting post-gap ('leadout pregap')...
finished ok, image created with 200268 sectors [44:30.18]
[06m 10s 030ms (VCDxBuild.exe)]
[CDRDAO Disk Info]
Cdrdao version 1.1.7
ASPI: C:\WINDOWS\SYSTEM\WnAspi32.dll
0,1,0: LG CD-RW CED-8083B Rev: 1.06
Using driver: Generic SCSI-3/MMC - Version 2.0 (options 0x0000)
That data below may not reflect the real status of the inserted medium. Reload the medium in this case.
CD-RW: NO
Total Capacity: 79:57:74 (359849 blocks, 702/807 MB)
CD-R medium: SONY Corporation
Long Strategy Type, e.g. Cyanine
Recording Speed: n/a
CD empty: YES
[01s 870ms (CDRDAO Disk Info)]
[CDRDAO Write]
WARNING: During writing you should avoid to open the Windows Explorer and similar tools
WARNING: CDRDAO does not lock the recording device so that all access action from the Explorer will lead to a failure of the recording process.
Starting write at speed 2...
Executing power calibration...
Power calibration successful.
cmd finished after 20.691s timeout 180s
ERROR: Write data failed.
ERROR: Writing failed.
ERROR: Note that CDRDAO troubles are often related to the use of an inadequate driver...
ERROR: You may have a bad "Force Driver" in the "CD Writer/Reader" settings page.
[26s 960ms (CDRDAO Write)]
[06m 40s 680ms (All tasks, and user interactions if any)]
