I'm trying to back up 'The Phantom Menace' DVD with DVD Decrypter, I Then run the resulting file through DVD2one, so it would fit on one DVD-R. Then I started to burn the file with nero, using the DVD movie option, The writing process doesn't report the any errors, but I get errors when it goes throught the verification process!
When I took the DVD-R out of my writer, and looked at the bottom, it looks like only some of the film has been burn't not all of it. I tried using a verbatim DVD-RW and and it burns fine, even plays in my Cybernet DVD player. When I try the same process with a DVD-R, I seem to burn costers. My DVD-RW drive is a Pioneer 105, I'm using Bulkpaq generation 4s 4x orange DVD-R and I'm burning at single speed, my version nero is 5.5.10.35. I've so far burnt five coasters.
Where am I going wrong?
Please help before I tear all my hair out.
Many thanks guys in advance
TEL
Results 1 to 11 of 11
I can tell you where you are going wrong straight away, Stop using NERO to burn DVDS. It just sucks for DVD's. Use Stomp record now max.
http://downloads.stompinc.com/files/stpRNM450e_STPD.exe
30 day trial, but if you live in the future its yours
Give that software a go if it doesn't work, then you can bitch at me.
https://www.videohelp.com/forum/viewtopic.php?t=166535
Proof Nero Sux's
Also haven't you tried DVD2DVDR using cinema craft encoder?http://dvd.coldpie.com - where you can download versions of DVD2DVDR. -
Originally Posted by wayned16
ps.I use Nero Express, and always get great quality DVD's.
GOOD LUCK,
SLICK RICKOriginally Posted by lordsmurf -
I'm gonna say throw out the bulpq's too!
or use 'em for DATA
and that thread here you SAY NERO doen't work???
well I follow youre link I found the story of someone who found a program called COPY TO DVD that fixed all his burning woes.
No nero bashers please! -
Originally Posted by SLICK RICK
@telthenipper,
did you look at the dvd burner compatibility of those DVD-Rs you bought. make sure that those specific DVD-Rs have been directly tested with the burner you have. if not, then don't trust it..unless you wanna take a chance...or maybe u know others who have successfully burned that brand with the same model burner you have.
btw, i personally don't think that cheepo media is really a problem..prolly just those specific brand of DVD-Rs...i'm using cheapo 1X princo ($0.81/each after tax in CA) and works great on my pioneer a04. -
Thanks guys for the info, much appreciate.
After a lot of fiddling about, I managed to get my movie burn to them Bulkpaq DVD-Rs. As I said I was running the ripped files thru dvd2one so I could fit the movie on one disk, well the default setting is 4.36 gb. I lowered the value to 4.2gb and it burnt fine at 4x!!!
But what I can't understand is why did it write to my dvd-rw fine at 4.36 gb but not the dvd-r?
What is the real maximum size of a dvd-r Disk? -
Originally Posted by telthenipper
traditionally, 1024 B = 1 KB; 1024 KB = 1 MB; 1024 MB = 1 GB...but recently every capacity is putting GB = 1000 MB, which is misleading....(i.e. my maxtor "160 GB" hdd is actually 152 GB). i guess it's new marketing strategy...like the n'vidia geforce 4's...which gets its ass kicked by geforce 3's and even some geforce 2's
The cheapo princos i use specifically holds 4489 MB w/ DVD overhead taking up 0.6 MB. hence, the biggest DVD i could burn would be 4488.4 MB. -
Originally Posted by poopyhead
4,700,000 bytes = 4472 MB = 4.38 GB = "4.7 Gig" DVD media
Anything over this is overburning, and you can only squeeze out another few dozen megs at most.
Lots of programs lie to you (like Nero 5.5.8.x), or it calculates from "size on disk" rather than true information size. So I understand how some people get wrong numbers (though still pretty close).I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Originally Posted by txpharoah
DVD-5
DVD-5 is a single sided single layer DVD that stores up to about 4 707 000 000 bytes and that is 4.38 GigaBytes where 1 kilobyte is 1024 bytes(4 707 000 000B / 1024 = about 4 596 679KB / 1024 = about 4489MB / 1024 = about 4.38GB) . Video DVD, DVD-R/W and DVD+R/W supports this format. Often referred to as "single sided, single layer".
Going mad trying to demux a TS
By twinaleblood in forum Video ConversionReplies: 16Last Post: 22nd Jul 2012, 12:54 -
Jump to menu is making me mad
By Allfreeware in forum Authoring (DVD)Replies: 0Last Post: 15th Dec 2011, 12:05 -
Problem Installing Lame - I think I am going mad!
By Janusian in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 15:15 -
WMV encoding driving me mad
By cutitfine in forum Capturing and VCRReplies: 2Last Post: 27th Dec 2007, 21:39 -
HV20 capturing is driving me mad!
By deadlantern in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 27Last Post: 26th Dec 2007, 01:11
