Ulead DVD MovieFactory 2 doesn't require program streams from what I can tell.
This is what the "replace audio" button does. Just select a clip in the timeline and then click the "replace audio" button...you can then specify the transcoded audio file.
Choosing elementary stream output option in SVCD2DVDMPG should be quicker, since it doesn't do the lengthy multiplexing step.
But, Chrissyboy, if you're reading this, why can't we have an output option where only the transcoded audio is output? This would be ideal for Ulead MovieFactory, and would be *much* faster (demultiplex audio only, and no multiplexing). In MovieFactory, you would add the original video and then use the replace audio option.
Originally Posted by LisaBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
3d subtitles don't regonise it at all - srt to all converter program
By fits79 in forum SubtitleReplies: 40Last Post: 9th Apr 2017, 06:31 -
mini dv tapes don't play sound, and video editing program can't locate time
By dave24 in forum Newbie / General discussionsReplies: 6Last Post: 1st Apr 2010, 18:58 -
OSX Program to Extract streams from .m2ts?
By marklight in forum Video ConversionReplies: 1Last Post: 11th Sep 2008, 23:27 -
I have a .DAT file and don't know what program I need to open it
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2008, 15:42 -
Program to just pull certain streams of audio.
By vodmare in forum AudioReplies: 5Last Post: 8th May 2007, 23:07
