HI !
Im own a philips dvd711 and i now know that it cant play dvd+-r that are under 4 gb of size .I just womder if this can be fixed with a new firmware or so???
Thanks![]()
Results 1 to 10 of 10
I don't know, I didn't test yet DVD < 4 Go but me I don't arrive at reading DVD-RW!!! However Dvd-r are read without problems but not the dvd-rw
I tested with Verbatim & Pioneer DVD-RW without success....
However I have the last firmware version 7.26 and other users arrives at reading the dvd-rw with DVD711, I don't understand....
People succeeded in circumventing the limitation of the 4 GO but I do not know how
I have a Philips 711 and I do not have such a problem. It plays DVD less than 4GB no problem. This is on both the DVD+R and DVD+RW and even certain DVD-R.
Firmware 7.22.
Perhaps it is the method rather than the player??!!.TOMMO -
I tested with firmware 7.22 -> unsuccesful
I use the same method as the dvd-r which them function, explains me perhaps holds that… -
Hi,
If you note that I stated DVD + R reads no problem. It makes up its own mind if it will play the minus format. Philips have confirmed that it wont play the minus format.
My burner is the PLUS format Philips 228 so all my disks are in PLUS format.TOMMO -
You this information from Philips has?However look at this post users affirm that Dvd-rw function on DVD711....
yes I took the information from Philips in the first place.
However, the main test, despite what others might say, is what WORKS ON MINE, tested by me.
DVD+R - All work.
DVD+RW - All work
DVD-R - Some work - very picky
DVD-RW - Never tried them.
MINUS format disks made using DVD2ONE and the COPYTODVD program work on the 711.TOMMO -
Thank you very much for this informations TOMMO
Other my Dvd-r function perfectly
I have played several dvd+r that are under 4GB without a problem on my DVD-711
Philips DVP3850
By guizzasan in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Aug 2011, 15:58 -
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Help Philips DVP3150V
By anitae in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2009, 11:06 -
philips dv 3120
By belairbelair in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Oct 2007, 16:44
