hello,
i have ripped a dvd with 0sex, so i end up with a VOB, i used to be able to use ffmpegx to convert it into SVCD. but since a few weeks it it's just not working anymore, so i installed everything new, including my system, multiple times. i've been trying to search for a solution on different forums, but it's just not working.
well here is what i get in the terminal,
Last login: Sat Jul 5 08:42:05 on ttyp1
pbpaste | sh
Welcome to Darwin!
[toyos-Computer:~] rogue% pbpaste | sh
Encoding started on Sat Jul 5 08:42:06 CEST 2003
mpeg2dec-0.2.1 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
Using altivec for IDCT transform
Using altivec for motion compensation
Frame rate code = 103823
MPEG in libvo = 82224 aspect_code=83496
/usr/bin/mpeg2enc: invalid option -- h
thanx a lot in advance,
Stay Human
Originally Posted by ghostdog1
I've seen that error too...
Disable "Encode hi freq" in the Options tab and it should work.
major: ist that caused by the latest compile of mpeg2enc?
as for the audio issue i suggest selecting another audio track in the Audio tab
and press play to hear if you have sound.
Cheers
Need Luna Player info and vob conversion
By hibbs in forum Video ConversionReplies: 3Last Post: 12th Feb 2009, 10:57 -
xbox360 won't play this avi,, codec info inside
By sance in forum Media Center PC / MediaCentersReplies: 11Last Post: 24th Dec 2008, 12:11 -
any inside info o whether or not xbox360 will support matroska in upcoming
By craig198 in forum Video ConversionReplies: 41Last Post: 31st Aug 2008, 23:34 -
Capturing from Hi8 Tapes using ATI or Dazzle DVC 90 ~more info inside~
By samyrk in forum Capturing and VCRReplies: 12Last Post: 18th Jul 2007, 08:54 -
screenshots for PAL DVDs (VOB files)--need frame info + step feature
By ezu0526 in forum Software PlayingReplies: 0Last Post: 8th Jun 2007, 15:06
