i have a samsumg 811 dvd, plays vcd an svcd, but no xvcd or xsvcd.
exists a trick -like de vcd trick- to play XSVCD ??? ( except the firmware upgrade)![]()
on the compatibility chart it says your player can play those formats.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
yeah man, but mine doesn´t play it. Maybe the model in my conuntry, CHILE, is not the same as in other parts of the world.
So, does anyone knows a trcki for playing XSVCDs??? -
you probably burned the files wrong. try burning in nero burning rom. just burn xvcd as non standard vcd and xsvcd as non standard svcd. if you burn them as vcd or svcd they might not work.Originally Posted by dinobikeAn all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php
And how i do that???
Unchecking the "create standard compliant cd " box ??
cause i've already do that, and still doesn't work
hmm well there might be another reason. do you use TMPGEnc. cause if you do on the bottom put settings and then go to the system tab and put MPEG 1 Video CD Non Standard. or if its an svcd just normal Super Video CD VBR.Originally Posted by dinobikeAn all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 09:42 -
Is there a trick to Fairuse Wizard for output file size
By marioval in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 06:49 -
wireless Networking (router trick)
By stiltman in forum ComputerReplies: 0Last Post: 25th Mar 2009, 23:18 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 08:36 -
Is there some trick to putting in a video card?
By videobread in forum ComputerReplies: 12Last Post: 21st Jun 2007, 21:07
