Ok so I have a .mov file I want to make a VCD out of, so I go to encode it and everything is working fine, a .m1v and .mp2 file pops up.. then a few minutes later I get an error:
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Volumes/WINDOZE/SMpromoVCD.m1v looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/WINDOZE/SMpromoVCD.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: [mplex] Selecting VCD output profile
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/WINDOZE/SMpromoVCD.m1v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 1:1.1250 (4:3 NTSC for 720x480/352x240 images)
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 1152000 bits/sec
INFO: [mplex] Vbv buffer size : 40960 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/WINDOZE/SMpromoVCD.mp2)
INFO: [mplex] AUDIO STREAM:
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 1412000
INFO: [mplex] target data-rate specified : 1411200
++ WARN: [mplex] Target data rate lower than computed requirement!
++ WARN: [mplex] N.b. a 20% or so discrepancy in variable bit-rate
++ WARN: [mplex] streams is common and harmless provided no time-outs will occur
INFO: [mplex] Sectors = 18 Video delay = 21600 Audio delay = 21600
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 47104 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Padding : sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=531600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 38544 frame=000158 sector=00000280
++ WARN: [mplex] Audio c0: buf= 2978 frame=000202 sector=00000065
++ WARN: [mplex] Padding : sector=00000066
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=891600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44799 frame=000276 sector=00000531
++ WARN: [mplex] Audio c0: buf= 3216 frame=000355 sector=00000114
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=1251600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44799 frame=000394 sector=00000776
++ WARN: [mplex] Audio c0: buf= 4096 frame=000504 sector=00000162
++ WARN: [mplex] Padding : sector=00000073
++ WARN: [mplex] Stream c0: data will arrive too late sent(SCR)=1611600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 47104 frame=000498 sector=00001033
++ WARN: [mplex] Audio c0: buf= 1817 frame=000638 sector=00000205
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=1971600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44808 frame=000624 sector=00001282
++ WARN: [mplex] Audio c0: buf= 4096 frame=000797 sector=00000256
++ WARN: [mplex] Stream c0: data will arrive too late sent(SCR)=2331600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 47104 frame=000736 sector=00001535
++ WARN: [mplex] Audio c0: buf= 1817 frame=000944 sector=00000303
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2691600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44799 frame=000838 sector=00001794
++ WARN: [mplex] Audio c0: buf= 4096 frame=001071 sector=00000344
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3051600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44799 frame=000965 sector=00002042
++ WARN: [mplex] Audio c0: buf= 4096 frame=001233 sector=00000396
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3411600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44799 frame=001081 sector=00002294
++ WARN: [mplex] Audio c0: buf= 4096 frame=001383 sector=00000444
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3771600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44799 frame=001214 sector=00002540
++ WARN: [mplex] Audio c0: buf= 4096 frame=001551 sector=00000498
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=4131600 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 44803 frame=001337 sector=00002790
++ WARN: [mplex] Audio c0: buf= 4096 frame=001707 sector=00000548
**ERROR: [mplex] Too many frame drops -exiting
Then it stops, but it already made the full .m1v and mp2 files... So I went to the tools tab in ffmpegX and under video tools I put in the .m1v and the .mp2 and press Mux as... VCD. It starts to encode and then I get the same error as before... data will arrive too late sent(SCR)=4131600 required(DTS)=0
So what am I doing wrong? Since I already have the full .m1v and .mp2 files is thier a easy way of making them into a VCD? Thanks in advance to anyone with any help or suggestions.
Hey thanks for the reply.. I tryed xvcd and got pretty much the same error...
INFO: [mplex] Setting best-guess data rate.
INFO: [mplex] Sectors = 32 Video delay = 38378 Audio delay = 38378
INFO: [mplex] Video e0: buf= 94208 frame=000000 sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=1282073 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 83929 frame=000402 sector=00000804
++ WARN: [mplex] Audio c0: buf= 3284 frame=000514 sector=00000165
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=1641869 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 91907 frame=000514 sector=00001058
++ WARN: [mplex] Audio c0: buf= 4096 frame=000657 sector=00000211
++ WARN: [mplex] Stream c0: data will arrive too late sent(SCR)=2001665 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 94208 frame=000635 sector=00001308
++ WARN: [mplex] Audio c0: buf= 1817 frame=000813 sector=00000261
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2361461 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 91903 frame=000748 sector=00001562
++ WARN: [mplex] Audio c0: buf= 4096 frame=000956 sector=00000307
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2721257 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 91903 frame=000849 sector=00001820
++ WARN: [mplex] Audio c0: buf= 4096 frame=001087 sector=00000349
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3081053 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 91907 frame=000979 sector=00002067
++ WARN: [mplex] Audio c0: buf= 4096 frame=001252 sector=00000402
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3440849 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 91903 frame=001093 sector=00002320
++ WARN: [mplex] Audio c0: buf= 4096 frame=001399 sector=00000449
++ WARN: [mplex] Stream c0: data will arrive too late sent(SCR)=3800645 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 94208 frame=001227 sector=00002565
++ WARN: [mplex] Audio c0: buf= 1817 frame=001570 sector=00000504
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=4160441 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 91907 frame=001348 sector=00002816
++ WARN: [mplex] Audio c0: buf= 4096 frame=001723 sector=00000553
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=4520237 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 91912 frame=001467 sector=00003067
++ WARN: [mplex] Audio c0: buf= 4096 frame=001875 sector=00000602
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=4880033 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 91912 frame=001578 sector=00003322
++ WARN: [mplex] Audio c0: buf= 4096 frame=002015 sector=00000647
I'm not any type of pro when it comes to video, but shouldn't a basic NTSC 29.97fps .mov file that I made in final cut pro be vcd compliant? I dunno any help is very much appreciated. Thanks!
SpiffySJGuest
I have a similar set of error messages when trying to convert an 800 MB high quality .MOV from iMovie to an MPEG 2. Were you able to figure out a solution to his problem?
Thanks!
-Shawn
Premiere Pro 'Error Compiling Movie - Unknown error'
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2012, 16:43 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
