(1) is it possible to save the created image of the vcd when burning so that i wouldn't have to go through the whole process again when i burn the same vcd? how do i do it?
(2) the vcd i'm burning has 2 avseq files in it. i can't fit the whole cd into one cd-r so i was thinking about separating the two and burning them into different cd-r's. is that possible?
thanks!
If you burn with NERO you can save or burn another copy as it gives you the choice on completion of the burn.
You can split the vcd with TMPGEnc. Go to Files/ mpeg tools/ merge and cut."Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Originally Posted by fishy`
If you use Nero, have it make a disc image first. Then you can burn that image to multiple discs ad infinitum.
If you are copying a VCD, I suggest CloneCD though most common CD burning apps will work fine. Have your program create a disc image first and then burn that to as many discs as you want.
Regards.Michael Tam
w: Morsels of Evidence
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 02:07 -
Creating Youtube (mp4) from mp3 and image
By robertpnl in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2010, 09:11 -
Best Image Quality burning AVI to DVD..
By UncleRuss in forum MacReplies: 9Last Post: 29th Jul 2009, 04:06 -
Creating simple text/image to prompt 'Insert Disc 2'
By rbatty11 in forum EditingReplies: 11Last Post: 15th Feb 2009, 12:08 -
Creating cartoon video from JPG image
By richnz in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2009, 15:18
