Ok I downloaded a subtitle pack with the extension of .zds. I know that I can use this file in a program called DVDSubber, which will overlay the subtitles over it's respective DVD in real time. The question is, how can I permanently insert this new subtitle track into the vob's ripped from the DVD. Is it possible with this format, or do I need to convert the subtitle type into something else?
So basically I wanna be able to rip a specific DVD to my hard drive, replace it's subtitle track with the new one I downloaded, and re-burn the dvd's so they will have the new subtitles.
Sorry I've never heard of the zds file format?? You can try to convert it (either with a tool or by hand) to another 'more standard' format:
http://www.doom9.org/subtitle_guides.htm
Most subtitle script files are pretty generic save for the header, so converting them by hand with a text editor really isn't that hard. Use to do it all the time for anime fansubs. -
Hmm, well in notepad and wordpad its just 100% unreadable code. So doing it by hand isnt possible.
Theres also one other problem. The DVD is a dual layer disc. The actual video on it that needs the new subtitles is larger then 4.7 gigs. So somehow I'd hafta patch the ripped vob's with the new subs, and then split them onto 2 DVD-R's...
Inserting subtitles in a Matroska
By Jomapil in forum SubtitleReplies: 5Last Post: 14th Apr 2012, 12:54 -
VisualSubSync plugin automatically inserting short blanks between subtitles
By zibizibi in forum SubtitleReplies: 1Last Post: 12th Jul 2011, 13:22 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10 -
HELP!! Inserting Subtitles to an .AVI
By poopy-underwear in forum MacReplies: 5Last Post: 13th Aug 2008, 19:53 -
Inserting subtitles into a movie
By aussiekev in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 06:13
