I wish to copy 2 VCD movies to 1 DVD - is this possible and is there a guide available anywhere? Everywhere i look does it from DVD to VCD/XVCD or SVCD
NEWBIE #1
PS
The Reason I wish to do this is so that i can watch the DVD on any DVD player such as XBOX & PS2NEWBIE #1 -
Guess no one knows....at last a question that even stumps the gods lol.....mmmm never mind
NEWBIE #1 -
Sure it possible, extract the mpeg files from the vcds using vcdgear, You can join them at this point if you want to using TMPGEnc. Then encode to DVD compliant mpeg with TMPGEnc, author and burn.
You can also create what is known as DVD-VCD where you can put the VCD mpegs onto a DVD without reencoding all you have to do is resample the sound to 48khz, this type of disc is not as compatible as reencoding though and you may find it wont play on your players. The guide for that is here
https://www.videohelp.com/vcddvdr.htm
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
