  1. Member Reaper88's Avatar
    May 2003
    I would like to make a short 4 or 5 sec intro to put in the begining of my dvd's. Just something along the lines of some animated text and mabey a still image or something. Can anyone suggest a program with which i could create a short video.
    Thanks.
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Any video editor should be able to handle that for you. Just output the finished video to MPG-2 and put it before the main menu or video you want in the DVD authoring app you are using.
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    check here...
    https://www.videohelp.com/forum/viewtopic.php?t=165926&highlight=
    plenty of good suggestions.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
