I am wondering how do I get the length of movies that I burn on a 4.3 dvd to be past 120 mins?
If I understood your question correctly, you want to fit more than 120 minutes on a 4.7Gb DVDR.
If so, the capacity in minutes is a function of the bitrate of the movie. Double the bitrate gives you half the time capacity.
4.36 Gb gives 1 hour if bitrate is almost 10Mbps. Cut the bitrate in half and you get 2 hours. Cut the bitrate to 2.960Mbps and you can fit 3 hours and 20 minutes (just encoded such a movie).
You control the bitrate by selecting appropriate options for the MPEG-2 encoder that creates the DVD movie.The more I learn, the more I come to realize how little it is I know. -
And using VBR instead of CBR can let you fit even more on the DVD with the same visible results as using the CBR. Lowering the audio bitrate can help too.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
How do i reduce encoding times,
By jamesj84 in forum Blu-ray RippingReplies: 5Last Post: 14th Feb 2012, 05:55 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Ripping subtitle times
By pfxz in forum SubtitleReplies: 2Last Post: 27th Jul 2008, 15:11 -
Burn AVI Video to DVD at different times onto one DVD
By 98xlt98 in forum Video ConversionReplies: 2Last Post: 18th Mar 2008, 08:58 -
Burn Times 3x longer after I installed AutoGK
By Gunewbie in forum ComputerReplies: 6Last Post: 19th Jul 2007, 21:45
