Now a real question
I have a movie that is split in 3 VOBs on the original DVD. The third part even has trailers in it at the ending. But i want to make 2 VCDs or SVCDs from it. Is it possible to make 3 MPEG files, cut the unwanted stuff from the third, then join the the rest and after that cut the resulting file again in 2 parts?
Or is there another, better way to do it?
pttpGuest
Myself I have never needed to rip a DVD so I don't know for sure, but....Originally Posted by pttp
Both TMPGEnc and MPEG2VCR should be able handle it. I know it works on MPEG files, and both programs say they can read VOB files.
But in TMPGEnc, I would only do two VOBs at a time, when merging more than 2 clips, I have had sync erors.
You could also look in the tools area for VOB Edit.--
Will
Yes.. there isOriginally Posted by pttp
You should be using the program OSEx (to be found on versiontracker.com). This program detectss wether a DVD is inserted or not. If it finds a DVD the program will give you the option wich Title you would like to use.. The longest one is useally the movie. Choose that, choose which chapters you want to have, which subs, which audio stream, which video stream (normally you can choose just one.) and rip!
" Military intelligence is a contradiction in term."
- Groucho Marx
A shame when Windows programs are offered in a Mac program forum isnt it!Originally Posted by willy_annand
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
Movie split on to 2 DVDs - make 1 movie.
By mattstan in forum EditingReplies: 3Last Post: 24th Oct 2008, 11:54 -
Split DVD into movie clips based on timing info in subtitle file.
By kwazi in forum Authoring (DVD)Replies: 1Last Post: 20th Feb 2008, 11:27 -
Can't join this movie that is split and already burned on dvd
By f-zer0 in forum EditingReplies: 3Last Post: 3rd Jan 2008, 22:21 -
hd-movie how to split
By jetli68 in forum EditingReplies: 7Last Post: 14th Aug 2007, 14:33
