As audio and video sync issues seem to be a very common problem, I thought I'd try list some of the reason's I've learnt may be the cause:
1) Is your hard drive fast enough?
Some of the older drives don't have a sustained data rate that can handle such a fast read/write scenario as capture.
2) Are you capturing to your primary hard drive?
Not the best idea.
If your financies stretch consider investing in a second hard drive, and use this only for capture, not part capture and part storage.
3) Do you have a VIA chipset?
Whilst I've heard many people have nothing but 100% success with these chipsets, I and many others had many problems which were only solved by changing motherbaords and ultimately chipsets.
If you have the chance, try aim for Intel and SiS.
Try a google search for 'VIA LATENCY' and you'll see what problems can occur.
A known problem chipset is the KT133.
4) Are you sure your system is configured correctly?
It doesn't hurt to run a thorough check of your hardware.
5) Are you veiwing the final mpeg with Windows Media Player?
If so, don't.
Try burning to a dvd-r/+r/cdr and viewing on a standalone, it may simply be the software your veiwing it with.
5) Do you have an onboard soundcard?
Onboard soundcards are real system drainer's, and are often the cause of audio/video sync issues.
Try borrow a PCI soundcard (I know that's not always easy) and see if your problem goes away.
6) How reliable is your source?
If you have a very poor VHS tape you're attempting to convert, check your capture settings?
For instance, Pinnacle Studio 8 is horrendous for analogue capture and in one of my attempts at 30 minute capture ended up five seconds out of sync!
Trying the same footage with Virtualdub (which has automatic correction) produced a flawless capture.
I'm by no means an expert, please feel free to add to this post as you see fit, perhaps we can all make it a definitive guide on this horrendous problem
Will
Results 1 to 30 of 66
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
ATI users with this audio & video sync problem may find the following post of some use:
ATI Capture ~ Gradual Sync Loss
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Thanks to SatStorm for the above link, it contains some useful information (courtesy of the makers of VirtualVCR) on audio/video sync issues.Originally Posted by SatStorm
Small tip-Latest Virtualdub versions have audio filters
While rencoding-audio-Use advanced filtering-audio- filters-add-doubleclick on input,stretch and output in that order-configure the stretch ratio to the ratio calculated as follows.
Go to video-framerate-under sourcerange adjustment-note down values in third line-change so video and audio durations match and current in first line.
Windows calculator, calculate the ratio of the first value to the second and enter it as the stretch ratio in the filter. After reencoding, the vid and audio will be in synch.
I had a PIII 800 with 20 GB hard disk earlier and did not get dropped frames or synch problem using Vdub and MJPEG codec even at 720x576 and 25 fps.
I have a PIV 2.4 GHz with 40 MB 7200 rpm drive-again no problem. I do not keep formatting or defragging my disk-I reboot every 2nd commercial break while capturing!! My card is the lowly Pixelview TV Pro with a Bt878 chip and now I use the Btwincap drivers-with my earlier PC I was using VFW drivers that came with thecard. -
Many thanks for this, I haven't tried it yet but I'll do some investigating.Originally Posted by mgh
Thanks for contributing to this 'pain in the ar*e' problem!
I capture with Pinnacle MivieBox USB with Studio 8 software, but I have video & audio sync problem, I try to use Virtualdub but when a try to open the capture mode appear a message "there is no capture device", can somebody have and idea to solve the problem?
I use Pinnacle Studio 8 with the Canapus ADVC - 100. I have no sync issues ever.
This combo does not know how to go out of sync.
Never dropped frames, no out of sync audio.
Pent 4, XP w/ SP 1, spinning 80 and 120 g HDs. Lots of memory crunching avi. I forget how much, but my VCDs are stunning, and better than VHS quality when Laser Discs are captured.
Jeff -
Sometimes it's the software. Before you think your system is to blame try to capture with Virtual Dub. It that works ok you can be sure your system is fine. I've come across a lot of capture softs that have sync bug problems BUILT INTO THE SOFTWARE.
I had no end of problems with Studio 7 and VideoWave 4 that no amount of tweaking would fix. I installed Scenalyzer and I never had a sync problem again. I haven't tried VirtualDub, so I might give that a shot as well.
My sync issues ended with the ADS Pyro A/V link, and a decent
DV capturing program.
Sheeeesh! all the wasted hours.
Still, making a proper VCD or SVCD is still a time
consuming process. Just no more problems. -
In my experience, all video captured PCI cards which do not have a built-in hardware sync twixt audio & video will gradually slide out of sync. The simple (free!) solution is to use the modification of VirtualDub called VirtualDubSync. This mod re-samples the audio otnhe fly so you don't get audio & video sliding out of sync. The downside is that on some systems you can only capture at 352 x 240 resolution, though you can capture to full D1 data rate if you want (technically 352 x 240 with D1 data rate is known as half D1). Or you can capture to standard DV AVI but at 352 x 240.
In any case, I can't see any singificant difference twixt MPEG-2 DVD video produced by a DV AVi file captured at 352 x 240 and one captureed in native 720 x 480 to DV AVI. At least, not on a TV set. On the computer, the difference looks obvious, but most people watch DVDs on their TV sets, not on their computers. -
I have been interested in solving an audio sync issue i have with a my video capture system. I have also read loads of news groups and suggestions but not really solved my problem at all.
I have a Dazzle DVCII capture card, Gigabyte intel Pentium IV 2.4GHz cpu and motherboard, two drives etc....
I can record a full movie from my DVD player without any problems with the audio sync, the movie looks great. Now if I use my Canon G2000 video camera I get terrible sync problems. (Camera is a 8mm analogue system).
Is there a way to improve the signal without having to buy a new camera?
thanks
marino -
I don't know anything about the Dazzle range but what is your source like?Originally Posted by cyberphox
You say it's 8mm so it's old, right?
The best option would be to run the analogue footage through a MiniDV camera with passthrough facility, do you know anyone with a camera you could borrow?
What software do you use to capture?
Is it part of the Dazzle setup?
My Dazzle Capture card uses software called Moviestar. Which I must say is not so great. The Dazzle drivers only allow you to use Moviestar, for example Adobe Premier cannot control the capture card nor any other 3rd party s/w..
My camera is old technology really and unfortunately I don't have a new camera to act as a pass through. I have tried recording the stuff on camera to a vhs tape and then record from the video tape, this did not help either.
Thanks,
marino -
BuggerOriginally Posted by cyberphox
Suggest you make a new post in 'capture', see if anyone with experience with Dazzle can assist (your question might get missed in here).
Good luck
The Hauppauge WinTV PVR-250 & 350 use WDM drivers, not VFW (Video for Windows) drivers, so VirtualDub software is likely not an option for users of this capture board hardware.
I have just installed pinnacle dc10. Im recording fine from the tv/video, but the playback is very distorted.
I have the sound settings low. Could you please tell me the best settings to have, please?
I have pinnacle dc10. Is it possible to change the screen size as its very small!!!
I'm haveing sound problem after I convert from avi to dvd with any software, it stutters real bad what's wrong with it, it's driveing me nut's I can't get right.Originally Posted by Will Hay
My comp and hardware never outsyncs video and audio.
Possible causes for VideoAudio Outsync may be.
heavily fragmented drives
slow drives -> 5400 RMP
slow interface -> ATA 33/66
cache too small -> 2mb cache
not enough ram -> 128mb ~512mb
ram too slow -> 333 mhz~400mhz
FSB to slow -> 266mhz~333mhz
Single Ram Channel
Overclocking
AMD process
Too many mobo features, usually onboard sound
Not enough resources free -> to many background progs running.
Crappy chipset -> VIA
Old firmware
Old drivers
Your still using last years programs that use DV 1
Your using a prog prone to drop frames and unsync
Your using anything less than Dazzle Hollywood DV-Bridge with a FrameSync chip built in.
Your processor is too slow.
You have a lot of crap connected to your peripheral web.
Slow Vid Card, resolution too high.
Old/crappy firewire cable
Old/crappy RCA/SVideo cables
Poorly Shielded Cables.
Page file too big.
Your still using the FAT/16/32 format for your hardrive.
You have crappy codecs.
Your a Mac User
Here is another interesting FACT:
It is common for MPEG 2 to be unsynced, most people dont notice it when they are watching TV. Truely, the NTSC MPEG 2 has a low unsync rate such as when watching DTV/SATV/HDTV etc.
XVid is also used for better sync.
PAL MPEG 2 has a lot worse sync, sync can be off for about 3-5 seconds.
Using DivX compression for transmission could have periodic sound loss, video loss, 10+ second lagging, and color loss.
As you can see NTSC SDTV is better even though it has a lesser res, and les colors, but higher frequency of fields, and higher framerate.\
SDTV 420i/p
EDTV 720i/p
HDTV 1080i/(p)ShDwScLaN -
As a past owner of a VIA chipset and all the soundblaster stuff also I can relate to all of the above posts. Anyone interested in capturing video my suggestion is to get an Intel chip motherboard. I've tried my onboard A97 Intel audio chip and it works fine also, but I generally run a Creative Audigy 2 card out of habit I guess.*()*
My experience with AVI capture has taken a very big turn for the better since I've started reading and posting on this forum. I've learned a lot from you guys and even from your mistakes. It's all good stuff, believe me. I want to say thank you all.
I've gotten into a habit of doing 2 things everytime I stop an AVI capture. I check the framerate and I check the audio/video stream length. My last 2 systems both use ATI AIW video/capture cards so i can't speak for other products but my experience has proven to me that if I can keep my framerate exactly on the money then calculate the 'offset' of my audio stream - I can produce in-sync MPEG encoded files from my AVI captures everytime. I simply use my calculated offset value in my MPEG encoder. Easy now, a nightmare before I figured that out.
I would add I have my system as streamlined as I can stand it, I don't abuse it by trying to over-clock or over-volt it and I don't install just any program I can find or own. My system is fairly bare with only the programs and tools I need and like to use and not much else. I've had so much trouble after installing bad applications I woudn't know where to begin.
Have fun with your video, and have fun on the forum. It's all good, either way.
Goood luck. -
A little trickly upgrading a motherboard to incorporate an Intel chipset if you have an Athlon
Intel or SiS chipsets are the choice for me
A slight note to shdwsclan:
When I started capturing video I was using a Celeron 400 e-Machine with 196 Meg RAM. I had a WinTV BT8x8 card, used WDM drivers, Virtualdub, MJEPG (18 ) compression, 640x480 resolution, a 30 Gig 5400 rpm 2M cache capture drive, and Win 98SE.
Never had any problems until I got a faster computer and bigger hard drives.
Does anyone know if this VIA KT133A chipset deal affects burning?
Basically, I have a 1.2Ghz Athalon, GA-7ZX-H Gigabyte KT133A motherboard and 768 megs of ram with an ATI 9600Pro video card. Everything works fine. I download videos and burn and no real probs "if" they're around 20min or shorter. Anything more , AVI or MPG, halfway through it just goes outta sync.
Tried the FAQs for the separating the audio etc and mostly never works the way it's described, and if it does, still outta sync anyways. Tried Ulead, SonicFoundry, and NERO for making DVDs, even formatted the drive and started fresh and same issue. 7200rpm drives, tried from the Primary and Secondary, umm... yeah... annoying issue driving me nuts.
Was gonna get a SiS based board since it's the only thing I can find that will hold my Athalon and my PC133 ram but I noticed this FAQ here is mostly about capturing, but a few posts sounded like burning issues. Any suggestions?
Odd thing too I'll mention is, I can create the DVD onto my HDD first, and from what I can tell it seems fine... I read a few latency issues with the VIA chipsets and thought maybe it's related.
In any case... since I posted this I ordered an ECS K7S5A PRO ATX SIS735 board and will post my findings. Thanks. -
Any luck?Originally Posted by Warlock_THR
The K7S5A is my board.
No not yet... ordered the board and a new case last Tuesday and the case (despite saying in stock) was backordered so, hopefully this week I can give it a go.
Are you having sync issues with this board? Even if it doesn't fix them, I'll still be happy. the VIA Latency issues and problems with Soundblaster and Radeon cards was enough for me to want to switch since it explained a lot of the problems I had in the past. Also, more USB ports and USB2.0 as well.
But I'll definately post either way, I'll use the same files and method and see if any luck, hope so, because the whole splitting audio from video, convert etc is hours and hours of something that shouldn't have to be done. And so far the 2 tests I did failed anyways. -
i have the same problem - but with mine i capture fine in sync - but when i convert my mpeg to dvd format it goes out of sync -Originally Posted by rrios01
This is old news but is worth to repeat here:
Everyone who uses digital camcorder in pass thru mode to capture analog video, never had audio video sync issue. Why ? The digital camcorder did such a good job in converting audio AND video at the same time to digital format to write on the tape (or to transfer to computer via Firewire).
The cheapest digital camcorder is in the 400$ range today.ktnwin - PATIENCE -
Hi, and sorry, didn't see this until now.
No, none at all, for what I paid I've loved this board, and still going strong after circa. 14 months.Originally Posted by Warlock_THR
Plus, I've installed three in upgrades for friends and family.
Strange, because whilst I love Studio for DV I'd never recommend it for anaolgue, it's a nightmare for audio/video sync issues.Originally Posted by PhreakPhish
I had issues with Virtualdub for a short time until I unclicked the box (words to the effect of): "lock audio to video".
Hang on, I'll post a screenshot.
After this, never had sync issues with Virtualdub again.
Audio Sync Issues!!!!
By earthXDust in forum EditingReplies: 3Last Post: 29th May 2011, 23:23 -
audio video sync issues after converting to mpeg with "Burn"
By wsgoogoo in forum MacReplies: 4Last Post: 9th Nov 2010, 19:02 -
Blu-ray Audio Video Sync Issues
By nerouser in forum Authoring (Blu-ray)Replies: 1Last Post: 24th Feb 2009, 15:38 -
Audio Video Sync issues with AVI.net
By siratfus in forum Video ConversionReplies: 3Last Post: 9th Aug 2008, 00:13 -
Audio Sync Issues
By Pinata in forum DVD RippingReplies: 2Last Post: 28th Jan 2008, 08:38
